ZC Swap: SI or ZC trany?
Old Jul 8, 2002 | 07:40 PM
1990hondaHF's Avatar
Default ZC Swap: SI or ZC trany?
Which trany is better and why? Thanks.
Old Jul 8, 2002 | 07:50 PM
Smokinsax's Avatar
The Boot
Default Re: ZC Swap: SI or ZC trany? (1990hondaHF)
Some body told me that the ZC has slightly shorter gears. I would probably go with the Si tranny since its way easier to get a hold of.
Old Jul 8, 2002 | 07:59 PM
-TJ's Avatar
-TJ
Default Re: ZC Swap: SI or ZC trany? (Smokinsax)
The ZC tranny does have shorter 1-5 gears. The drawback is that the ZC is handicapped by a DX final drive (3.888). Put the Si FD (4.250) into the ZC box and you've got a great gearbox. Transplant the Si 5th gear in too and it's even better.
Old Jul 8, 2002 | 08:19 PM
Default Re: ZC Swap: SI or ZC trany? (-TJ)
Final is the 5th gear?
Old Jul 8, 2002 | 08:26 PM
Art T. Fish L.'s Avatar
what TJ said is the best advice i was going to tell you the same. This setup is going to be my tranny for my future sohc vtec project.
No, final is your differential's ratio. Think of rear-wheel driven cars and their differential is near the rear axle. Well, since our cars are front-wheel drive, just think of having the differential located inside the transmission housing. HTH
Old Jul 8, 2002 | 08:28 PM
-TJ's Avatar
-TJ
no. YOu have the 1-5 gears on the main and coutershafts, and then you have the final drive ratio which is a large helical gear on the end of the countershaft and the ring gear on the diff.
a final drive set requires a ring gear and a countershaft.
a 5th gear set is two donut shaped gears which slide onto the main and countershaft.
see the exploded view of the tranny - you'll get it.
Old Jul 8, 2002 | 08:30 PM
If had to at this point make a choice between one or the other which one comes out the winner? Si or Zc?
Old Jul 8, 2002 | 08:31 PM
crx(gator)'s Avatar
wasnt someone on HT selling a Si tranny with ZC gears and a Si final drive in a Si tranny casing, if they still have it im interested...
Modern91Hatch
Apr 25, 2008 08:38 AM
NightHawkC5
May 2, 2006 04:28 PM
DOHClessEF-9
Feb 16, 2005 07:56 PM
QuarterMileMaster
Aug 26, 2004 10:59 AM
BseriesHatch
Jun 3, 2003 09:39 PM
