toe is really bad after front LCA install
so i removed the front LCA's today to get some bushings pressed in, and now that ive got them mostly installed again, i can tell that the toe on the two hubs are way off, like i can notice the difference just by looking at them. Am I going to be safe driving a mile or two to the alignment shop or am i going to suffer because of this? is there anything i should do to avoid further problems?
Here's a guide on fixing your own toe if its that bad. You probly won't make it perfect but at least you'll save yourself on some possible dmg you will take driving to the alignment shop.
http://www.hondapoint.com/foru....html
If u decide to drive, don't get on a freeway. Your car will be very unstable at higher speeds. Also don't accelerate hard or you will get pulled whichever way your tire with the most traction is pointing.
JamesTheMage
Feb 28, 2013 05:23 PM
Racer X
Jan 30, 2003 09:13 PM
