MPFI Help!
Old Mar 19, 2008 | 04:10 PM
wreckeddc4's Avatar
Default MPFI Help!
I just finished my mpfi swap in my 90 civic std... i swapped a complete d16a6, i have all the grounds hooked up now and it rolls over... now its throwing a code 20 at the ecu... what are some of the most common mistakes that are made and cause the code 20...? I also relocated the battery to the rear if that makes a difference, but it shouldnt I used Og wire to a distribution block and to the starter= fusebox... HELP PLEASE
Modified by wreckeddc4 at 2:58 PM 3/20/2008
Old Mar 19, 2008 | 04:21 PM
crxricer66's Avatar
Default Re: MPFI Help! (wreckeddc4)
it sounds like it goes on the "bolt" that is on the starter, its your main power for everything. it slides onto the bolt and there is a nut that goes on it. good luck
Old Mar 19, 2008 | 04:39 PM
894doorDX's Avatar
Like was said above it could be the main wire for the starter.The ground for the thermostat housing is right around that area also.Its alot smaller but also has a ring terminal on it and the car will not start if its even loose a lil bit.
On another note I did thesame swap in the same exact car.What a world of difference.The only other thing I would suggest is if you didn't get the si tranny to do it.Best of luck buddy
Old Mar 19, 2008 | 04:40 PM
wreckeddc4's Avatar
Default Re: MPFI Help! (crxricer66)
Thats not it, i have that hooked up, its smaller, similar to the wire that goes into the under hood fuse box but it is closer to the motor on the harness...
Old Mar 19, 2008 | 04:44 PM
wreckeddc4's Avatar
Default Re: MPFI Help! (894doorDX)
Thermostat housing ground sounds like my best bet..... would there be voltage showing at it? I put my multi meter on it and it was showing like 6 volts, if its a ground maybe its because the current is trying to exit there?
one-cam
Nov 10, 2008 06:13 PM
DarkBB4
Apr 23, 2007 10:47 AM
vtecn8ive
31
Jul 1, 2005 07:57 PM
crexer
Dec 23, 2004 10:17 PM
