96 Honda Accord has no Spark
can someone please help. I have replaced the plugs distributor cap and rotor also the coil and I still have no spark? dont know what to do.. Thanks . Mechanic says he thinks its the computer. also its getting fuel
Modified by knowmolyes at 2:42 PM 3/19/2008
with the key turned on make sure you have 12V at the black/yellow wire at the dist.
if thats okay; you can check the ignitor with a test light; put a spark plug lead about 1/4" from the output of the coil, then key on, use the test light with one end of the test light grounded; then touch the test light probe to the ignitor terminal with the blue wire going to it. The coil should throw spark.
Did the mechanic pull out the ashtray and check for codes?
Eric Graham
43
Mar 12, 2014 07:28 PM
