crx h22 need help wont start.
my crx wont start. heres the prolem and how it happen. iwas doing a pull in third gear hit the nitrous switch and then it just all shut off. no boom bam or anything. i have checked the main relay its not making any noises when its side the car so it doesnt work when its in the car but i have pulled the relay out of the car and check it to see if it works and it does just fine and i have three other main relay to that i have check and put it and there were from one of my other cars that runs and it works. the fuel pump isn't turning on. theres no spark. the vtec controller isn't turning on. when i ground out the blue wire of the wiring harness to give me the flash codes (the engine light) nothign happens. but when turn the key on the light turns on and stays on.(wont turn off when i ground that wire off to)
i'm really lost please help
oo and i replaced the fuel pump and checked the wiring to the fuel pump its also is good. the ground on the themrostat housing is on and good. i checked all the fuses under the hood of the car. under the dash i checked all the fuses to but i lost the cover of the dash that tells the apms for those ones. but nope of those are broken.
well thank all you honda tech little boys. for the great help as in saying nothing i found the problem myself. i thought you guys knew your stuff and could help i guess not.
hey for the fuel pump, is a fuse my car did the same when i put in a new fuel pump. check fuse no 14 I think or all of them. If is bad then that's your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BobbyGh22crx »</TD></TR><TR><TD CLASS="quote">well thank all you honda tech little boys. for the great help as in saying nothing i found the problem myself. i thought you guys knew your stuff and could help i guess not.</TD></TR></TABLE>Sometime you just have to find out for yourself. You aren't always going to find the answers by asking for help. ...and most of the time, it is very difficult to diagnose over the Internet or phone.
Don't get your panties in a twist over something trivial.
...and it is against the rules to bump your own posts. Just saying.
Ruggeh
31
Jan 10, 2016 12:00 PM
GUNMETALREX
Jun 13, 2009 10:32 AM
92nahatch
Sep 16, 2008 01:05 PM
grkblood13
Aug 28, 2008 04:22 PM
fracas
26
Dec 11, 2005 08:59 AM
