Accord 96 2.2 engine failure
Old Mar 19, 2008 | 09:44 AM
kc93buckeye's Avatar
Default Accord 96 2.2 engine failure
My wife was driving our 1996 accord (2.2 l) and she heard a "snap" and the engine started making a "clanking" noise. She drove it home. My first thought was the timing belt broke, but how would the engine keep running? Also, I had the timing belt replaced last year. So after oppening the hood I found two spark plug wires off the enngine and the #4 spark plug was gone. After I pulled the #3 plug it was covered with oil. So, I know have a blown head gasket. But what else is likely? broken camshaft? Scored pistons? Also, would the engine run with a broken timing belt? Finally what would cause or where would the pressure come from to blow out the sparkplug (pressure in crankcase)? As you can tell I am not technical so any help here is greatly appreciated.
Old Mar 19, 2008 | 10:58 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Accord 96 2.2 engine failure (kc93buckeye)
Definitely not the timing belt
Old Mar 19, 2008 | 03:44 PM
m735is's Avatar
Not tightening the spark plugs enough can cause them to work their way out. I would install new plugs and start it. Just loosing the plugs doesn't necessarily mean the head gasket is blown.
If the number three plug was covered in oil on the outside, you just need a new valve cover gasket set. If it was covered on the plug tip, then you have other issues.
the_cynic
Oct 18, 2018 02:19 PM
Barmaleyka
Aug 29, 2014 09:11 PM
TurboBB2
Oct 29, 2010 05:22 AM
Dropped90Integra
Jan 21, 2006 09:24 AM
