edm-crx si with d16z5 (euro zc)
Old Mar 19, 2008 | 04:28 AM
edm_ef8's Avatar
Default edm-crx si with d16z5 (euro zc)
hey im new to Honda-tech and tunning so if i mess something up sorry. anyways i have a d16z5 a zc pretty much. i just bought high comp pistons for it it has bad rings so i figured to go high comp with it. im not looking for a huge performance gain or a big build up. i wanted to know if i will have to chip or tune the ecu for the pistons or what? and also anyone know the main bearing torque value i haven't been into allot of Honda's before sorry for the long post and hope i have all the info for you.
thanx
Old Mar 23, 2008 | 11:55 PM
ZBracing's Avatar
Default Re: edm-crx si with d16z5 (edm_ef8)
good luck
Old Mar 24, 2008 | 12:32 PM
superex87's Avatar
I believe with the high compression pistons that you have to retard? or advance? the timing with an adjustable cam gear, Im pretty sure it has to be retarded but I could be wrong about that.
I think thats all that has to be done if your just adding the high compression pistons.
Old Mar 25, 2008 | 09:35 PM
edm_ef8's Avatar
yeah i knew i would have to do the advancing with the timing and i think with my application i should be fine with just doing it by the distributor for cam gear i thought it was more for after market cams idk guess ill look it up haha
rev_this
Apr 24, 2008 09:59 AM
hatchinprogress
Nov 23, 2005 11:27 AM
jap-in-da-box
Sep 14, 2004 01:48 PM
ITSTOCK
12
Jun 6, 2004 09:16 AM
bigblu333
Jan 17, 2004 08:05 AM
