Wires for headlamps.....PLEASE HELP!!!!!
Not sure if my title makes any sence.But after my car has been jumping to shop after shop and after I did my whole JDM ITR FRONT-END the wiring for my headlamps from my car have gotten really "rigged" I meen somehow my wires on my car have gotten cut really short,I have alot of wires just hanging that are not even being used!My car at the moment is at the shop but they are not able to wire up my headlights due to this situation......What can I do in this situation besides taking it to the actual dealer????PLEASE HELP!!!!!I will try and explain more if needed
Dismissing the fact that a shop says they can't wire your headlights even though that is what they do, you can either splice in new wires or just run new wires from end to end. It sounds worse than it is, once you figure out where they go, you and a friend should be able to pull new wires fairly easily. Did the shop say they couldnt do it ONLY because the wires are too short or was something else not right?
averyvm
Nov 3, 2005 10:17 PM
