94 gsr problems
I recentlt blew my head gasket. But before all this happen for some reason my car wouldnt blow out out air when its on the heater. I'll put it on heat but it blows out cold air. And everytime I put coolant in my car while im doing it, it comes right out where it comes from. So i went to change my thermostat (i spelt it wrong) and it still does the same so it must be my water pump. Any suggestion what should i do about the heater part. and any ideas if my water pump is bad or not.
You are terrible at wording whatever it is you're trying to say. It sounds like you've got an air pocket. Were you losing coolant? I think you just needed to bleed it properly.
But with a blown head gasket you have a little bigger project than fixing heater woes.
A bad thermostat would explain your heater not blowing out hot air. Is the car engine heating up to the proper temperature?
But like that other guy said, you need to fix the head gasket before worrying about being cold.
I just got done pulling my head gasket and on Gsr is just an ***. they have like a lil bracket behind the intake mani for safety. But when i pulled it that head gasket look just fine.
StupidSlowRSX
Dec 17, 2007 07:00 PM
