my 97 del sol sounds like a deisel engine... help!
Old Mar 18, 2008 | 07:54 PM
paTECH's Avatar
Default my 97 del sol sounds like a deisel engine... help!
all of a sudden my 97 del sol started making this fast knocking noise coming from the driver side of the engine. i have a d16y8 motor. the car now only revs to 3000 rpms and dies out after a few minutes idle-ing. what can be the problem??? if anyone knows what this problem might be, it would help me alot.
Old Mar 18, 2008 | 09:13 PM
fizik's Avatar
Timing skipped? Thats my guess =X
Old Mar 20, 2008 | 12:11 PM
paTECH's Avatar
Default Re: (fizik)
that is likely. any more suggestoins?
Old Mar 20, 2008 | 12:19 PM
crazyguy's Avatar
Default Re: (paTECH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paTECH &raquo;</TD></TR><TR><TD CLASS="quote">that is likely. any more suggestoins?</TD></TR></TABLE>
take valve cover off and inspect timing belt for any damage. if timing belt is in good condtion and tight. then check fuel injectors. a faulty fuel injector could cause the same problem too. it happened to me once.
Old Mar 21, 2008 | 11:16 AM
paTECH's Avatar
thanks for the help!
Old Mar 21, 2008 | 01:20 PM
eg8tuner's Avatar
drain/check oil or take off plan and see if u still have bearings in their. mine made an awful clunk when the bottom end went. look for metal in the pan
97dssi
Jun 7, 2010 06:48 PM
TupacWasMyDad
Dec 7, 2009 12:20 PM
Jason P
Feb 18, 2008 12:33 PM
oldsklcrx
Nov 9, 2005 12:46 AM
