power windows help
Old Mar 18, 2008 | 07:21 PM
davgonzalez1@aol.com's Avatar
Default power windows help
i have a 1995 accord ex 4dr. both my front windows go up and down slow. they look like they are pushing the window motor and theycome off the track.they start out slow then they go fasster. i get the felling thatsomething is putting pressure on them. So i opened up the door panel to take a look. the two wires that that are tugged when you pres down or up on the power windows. well one of the wires looks like it is pressuring against the window. is there anythig i can do
Old Mar 19, 2008 | 04:06 PM
hondadude's Avatar
Default Re: power windows help (davgonzalez1@aol.com)
Get new regulators and lube the window run channels with silicone spray, or Shinitsu silicone grease from the Honda dealer.
I'm pretty sure there is a small amount of adjustment for the window tracking; at the bottom of the run channels there is a 10mm bolt that you can loosen and pull the channel towards center. Also there should be some manner of tilting the regulator to change the front to rear angle of the window.
F23A11990Accord
Oct 26, 2009 06:04 AM
jdm_jeners
Sep 8, 2006 07:59 PM
MtbikingKing
Jan 19, 2006 08:21 AM
cd555
Aug 31, 2002 03:35 PM
