Steering is becoming progressively stiffer
Old Mar 18, 2008 | 06:42 PM
streetmodified's Avatar
Default Steering is becoming progressively stiffer
My steering is getting stiffer and stiffer. I have a 1990 si with an ITR motor (heavy). lowered on stiffer springs (#500F, 400R), and wider tires (205?). Given all that - the car has always been a bitch to steer, since it doesnt have power steering. recently, its been even tougher.
the chassis has almost 150,000 miles on it, and has seen 5 years of pretty brutal autocross. could this be a problem with the steering rack needing to be lubed and / or rebuilt?
thanks
Modified by streetmodified at 7:54 PM 3/18/2008
Old Mar 18, 2008 | 06:45 PM
Default Re: Steering is becoming progressively stiffer (streetmodified)
everyone loves photos:
the ailing si
Old Mar 18, 2008 | 11:28 PM
K2e2vin's Avatar
Tires going flat?
Also, have you checked the bushings/joints, make sure they're not dry?
Old Mar 18, 2008 | 11:53 PM
rayzian's Avatar
Default Re: (K2e2vin)
I have the same problem. I noticed that if I move the wheel too there's this loud squeaking noise coming from under the car as well, is yours the same? Luckily I still have the light B2 in there
Old Mar 19, 2008 | 07:45 AM
rbwdriven's Avatar
my crx was doign the same thing. I pumped up the tires and the issue went away. I had 20 on one and 25 on the other.
Old Mar 19, 2008 | 01:39 PM
not the tires. just went to 36 all around before i started driving it again this spring.
not the bushings - i did the full kit for the car about a year ago.
i was wondering if the steering column needs to be lubricated or rebuilt?
Old Mar 19, 2008 | 03:20 PM
K2e2vin's Avatar
None of the EF's I've owned has had problems with the steering column, so I can't say.
What you can try, is jack up the front end, put the keys in and see how freely the knuckles and steering rack move.
Have you tried checking to see if the bushings are still lubricated? Tie rods?
Old Mar 19, 2008 | 06:21 PM
funny, my old man recommended the same thing. im gonna try that this weekend. thanks
Old Mar 19, 2008 | 07:05 PM
saikouEF8's Avatar
so u changed the suspension and tire size....have you had an alignment since then? maybe your toe and camber is off...
i had a rack go bad but i knew because the steering became ridiculously loose...
Old Mar 19, 2008 | 08:00 PM
snowseeker's Avatar
Default Re: Steering is becoming progressively stiffer (saikouEF8)
Maybe your just getting old and weak!
99% sure your looking at replacing the steering rack.
Old Mar 19, 2008 | 08:13 PM
DailyDriverCivic's Avatar
It pretty much has to be in the rack/column. I would doubt the column though. The bushings/tierod ends,ball joints would have to be pretty severely damaged to even notice a slight difference at the steering wheel. Evan at that, I don't see the bushings ever affecting sterring ability. I cant imagine why you would run one of these cars without power steering anyway...
Old Mar 19, 2008 | 08:22 PM
Bob_760's Avatar
Default Re: Steering is becoming progressively stiffer (DailyDriverCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyDriverCivic &raquo;</TD></TR><TR><TD CLASS="quote">I cant imagine why you would run one of these cars without power steering anyway...</TD></TR></TABLE>
Is this somehow a typo or are you joking?
Old Mar 19, 2008 | 08:40 PM
Default Re: Steering is becoming progressively stiffer (Bob_760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">
Is this somehow a typo or are you joking?</TD></TR></TABLE>
Naw, I am just getting old these days, and can't stand having no power steering. When I was younger, I was anti-PS all the way. Just not worth the weight/power savings to me in my old age.
Old Mar 19, 2008 | 09:07 PM
Bob_760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyDriverCivic &raquo;</TD></TR><TR><TD CLASS="quote">Naw, I am just getting old these days, and can't stand having no power steering. When I was younger, I was anti-PS all the way. Just not worth the weight/power savings to me in my old age.</TD></TR></TABLE>
Fair enough.
Nice choice of avatar btw...
Old Mar 20, 2008 | 01:23 PM
Default Re: Steering is becoming progressively stiffer (snowseeker)
haha, getting old maybe - but still putting up 200 on the ol bench.
yeah, the car never did have PS, so i never put it in. It might be something worth considering. it makes plenty of power anyway - so thats not really a concern. i guess a re-alignment is never a bad thing anyway. At this point, it'd probably get an aggressive race alignment, since i bought an AP1 for a daily
(yeah, i just said that)
anyway, i'll put her up this weekend and take a look. i'll report back on monday.
SM
ps - this is the faster of the two cars FTW
zenon8890
Mar 30, 2010 06:57 AM
^MikeG
May 23, 2006 08:40 AM
cbp_crx
Feb 7, 2006 02:34 PM
Tyson Ballou
Jan 5, 2003 12:01 AM
01PYTypeR#1140
Nov 19, 2001 09:47 AM
