timing belt drive pulley removal
Old Mar 18, 2008 | 04:21 PM
EG6 Love's Avatar
Default timing belt drive pulley removal
as the titles says. im trying to remove the timing belt drive pully on a f23a1 and i cant get it off. i got the engine for free and i have no intentions of making it run because its shot but i want the crank, rods and pistons out. ive even broken some of the flange off cause i pulled so hard on it.
help me out please!!
theres gotta be a trick to it?!
Old Mar 18, 2008 | 05:01 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: timing belt drive pulley removal (EG6 Love)
So you have already removed the crank pulley bolt? The pulley should just slide right after removing the bolt. If not, try spraying it with PB Blaster and see if that helps loosen the rust or whatever is keeping the pulley stuck on the crank.
Old Mar 18, 2008 | 05:15 PM
hondadude's Avatar
PB Blaster is your friend
Another trick is to get a small chisel under the key and pry it up a little then get vise grips on it, try to get it out. If you get the key out you can twist the pulley a little.
I've also driven them in a little with a big socket to get them to loose their hold on the crank, then wiggle them off .001" at a time.
Another thing that happens with that situation [pet peeve] is people see the key sticking out a little at the end of the crank and then pound the key in, and that wedges the key against the T-belt pulley, because the end of the keyway slot is slanted.
The flippin key is SUPPOSED to stick out a little bit ! !
Old Mar 18, 2008 | 05:28 PM
EG6 Love's Avatar
ive already got the key out and the pulley will slide back and forth but will get stuck when u get about .5 mm from the edge and wont move for ****.... a pry bar, hammer, or very slowly moving it with my hand a lil at a time wont do it either.
ill try some pb blaster though
Old Mar 18, 2008 | 05:33 PM
H-T Order of Merit
Default Re: (EG6 Love)
not sure what else would hold it up if you are able to move it that far already. See if PB blaster helps, couldn't hurt.
civiclady
Sep 13, 2015 06:33 AM
newlude8657
May 3, 2012 10:29 PM
dfabulous
10
Dec 9, 2007 11:00 PM
Bullet113
Dec 7, 2006 02:16 PM
h46it
Mar 21, 2002 07:57 AM
