Suspension & Brakes Theory, alignment, spring rates....
Traction bars and front sway question?
Old Mar 18, 2008 | 03:32 PM
siblues's Avatar
Default Traction bars and front sway question?
I was wondering if on a EM1 with the front sway if its possible to use the regular full-race traction bars and keep the front sway?I have the regular ek arms on the car right now but the sway doesnt work with the setup and I have been told that the ek sway will work?
Old Mar 18, 2008 | 05:10 PM
VTEC_PRODUCTION's Avatar
Default Re: Traction bars and front sway question? (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if on a EM1 with the front sway if its possible to use the regular full-race traction bars and keep the front sway?I have the regular ek arms on the car right now but the sway doesnt work with the setup and I have been told that the ek sway will work?</TD></TR></TABLE>
if the traction bar is setup correctly then they should not interfere with the sway bar...
Old Mar 18, 2008 | 05:59 PM
siblues's Avatar
Default Re: Traction bars and front sway question? (VTEC_PRODUCTION)
I am not asking whether they will interfere or not they are already on the car with no interference.I am asking if I switch the lower forks on the car to the non si forks can I still use a front sway bar and what is needed?
https://honda-tech.com/zerothread/2251881
Modified by siblues at 11:15 PM 3/18/2008
Old Mar 18, 2008 | 06:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">I am not asking whether they will interfere or not they are already on the car with no interference.I am asking if I switch the lower forks on the car to the non si forks can I still use a front sway bar and what is needed?</TD></TR></TABLE>
i dont see why not. why would you do that anyway?
Old Mar 18, 2008 | 07:15 PM
siblues's Avatar
Because on the EM1 the traction bars tend to bind and cause problems with the bushings since they mount different on that model.
Old Mar 19, 2008 | 11:07 AM
well, you got me...
Old Mar 19, 2008 | 03:17 PM
siblues's Avatar
Ok I have one quick question then are the non si and the si sway bars the same except for the thickness?
jrunager
Suspension & Brakes
23
Oct 24, 2012 10:30 AM
Midori Green
Aug 21, 2008 06:36 PM
BlackEG6
Sep 3, 2006 08:04 AM
EGO
15
Feb 4, 2003 07:15 PM
jdmhamster
Sep 21, 2002 09:47 AM
