Turn Signal wiring help needed
Old Mar 18, 2008 | 03:06 PM
Caveman74's Avatar
Default Turn Signal wiring help needed
I have an 01 V6' . It was recently in a wreck. The right side {Passenger} turnsignal clip was crushed. I need the diagram of how all three wires are in the clip. It is all f'ed up and blowing the fuse.
I have switched them around and cant get it right.
There is a green, red and black.
Old Mar 18, 2008 | 05:00 PM
hondadude's Avatar
Default Re: Turn Signal wiring help needed (Caveman74)
The Green/yellow stripe goes to the turning signal bulb/ Black is a shared ground for both bulbs. Pin 2/center of the connector
The red/black stripe is going to the parking/marker light. Pin 3 of connector.
Have you followed the harness back to be sure it wasn't crushed somewhere else and is grounding out?
Old Mar 19, 2008 | 01:45 AM
Caveman74's Avatar
Default Re: Turn Signal wiring help needed (hondadude)
I need to know how all 3 wires connect to the pigtail clip.
.^.----clip part up
{ o o o} ---- clip looks like that, in what order do the 3 go. Thanks
thrasher324
Dec 28, 2016 01:59 PM
justaskgrandpa
Apr 3, 2016 10:34 AM
jdmeg6hatchy
Feb 26, 2012 06:07 PM
bodazappa
Jun 13, 2004 03:12 PM
Gennady
Feb 9, 2002 06:29 AM
