b16a transmission help
Old Mar 18, 2008 | 02:14 PM
loba's Avatar
Default b16a transmission help
So my tranny started making an awesome ticking noise on Thursday. I thought, okay, I'll check it on Saturday. I never got the chance. It blew on Friday.
Here's the deal. I took it to a shop because I don't have the time or tools to replace it myself, but the guys over there have no idea what it is. The block is a b16a, and the numbers of the transmission are SI-1050642. I have a 91 CRX Si. Could this be the stock transmission before the guys before me swapped the engine?
If so, what should I have them look for to replace it, that won't cost me an arm a leg and an ***, and that'll fit without difficulty.
Thanks in advance.
Old Mar 18, 2008 | 02:29 PM
loba's Avatar
Default Re: b16a transmission help (loba)
EDIT: It must be S1 not SI. So the question is where the hell can I find one in the Portland, OR area?
Old Mar 18, 2008 | 07:51 PM
HmgLauj69's Avatar
try here
https://honda-tech.com/zerothread/1967953
Old Mar 18, 2008 | 08:53 PM
Gearspeed-Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loba &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: It must be S1 not SI. So the question is where the hell can I find one in the Portland, OR area?</TD></TR></TABLE>
Look for a YS-1 if you can find one! The s-1 is a dinosaur and most parts for it are obsolete if you need replacements.
The short geared YS-1 from the USDM 92-93 or the JDM Integra XSi are very rare but, are the best cable trans you can get.
The YS-1 will require a different clutch disk Uses 92-up.
Parts for these transmissions are interchangeable with newer Hydro B series vtec transmissions and are readily available
Old Mar 19, 2008 | 09:03 AM
loba's Avatar
Default Re: b16a transmission help (Special Projects MS)
So help a drugged up buddy out (I JUST had my wisdom teeth pulled). The shop is doing the replacement. What car should I tell them to look for? IT's stamped ys1 right? And what clutch should I have them look for to match (I don't need a performance clutch it's a stock motor).
Thanks a lot for the input.
EDIT: The half shafts I have and all the other stuff should match up fine right?
Old Mar 19, 2008 | 03:56 PM
loba's Avatar
self bump for hydrocodoone!!!1
Old Mar 22, 2008 | 09:18 PM
It will be from a USDM 92-93 GSR...very rare. Be careful because the LS also shares the same YS-1 tag code The clutch disk will be different due to the spline count on the mainshaft. So you will need a 92-up Integra clutch
Old Mar 23, 2008 | 11:45 AM
loba's Avatar
I'm looking at a local 90 YS1, what's the difference?
NVM found it. Looking at a 93 YS1 for 400 - deal? And I would need a 92-93 clutch right?
Old Mar 23, 2008 | 12:13 PM
Yes you would need a 92-up clutch disk
Its a deal if it is short geared and good transmission.
Crack it open and inspect it before buying it. I would hate to see you buy a 400 boat anchor.
Old Mar 23, 2008 | 02:49 PM
loba's Avatar
What should I be looking for when I open it?
Again, I'm assuming the incompetent folks over at the place where my car is haven't found something.
Old Mar 23, 2008 | 06:46 PM
Counting the teeth to make sure it is short geared. The ratios can be found on here if you search and there are a few other B series gear ratio charts floating around.
Also checking the synchromesh areas to make sure they are still good and at a point...not smashed over.
Old Mar 25, 2008 | 09:21 AM
loba's Avatar
Thanks for the help. Couldn't find the holy grail GSR YS1 - but I ended up getting a freshly rebuilt (from a shop) LS 92 YS1 - with a GSR 5th gear (not sure why the guy did that). It'll work for now my car will just feel a little slower, but dammit I needed my car working.
jonezyboy6
Jan 24, 2008 04:53 AM
Soullessone
Jul 14, 2005 08:03 AM
g2tegsown
11
Jun 10, 2005 08:36 AM
conceptEG
Sep 5, 2003 09:35 PM
Quicker
Aug 24, 2003 09:28 AM
