HID's full plug and play kits $125 shipped 1 year Warranty
Old Mar 18, 2008 | 01:28 PM
hughbie2002's Avatar
Default HID's full plug and play kits $125 shipped 1 year Warranty
<FONT COLOR="red">I am selling the full plug and play kits for $125 shipped or $150 installed Bi-Xenon $185 shipped or $225 installed </FONT>
<FONT COLOR="blue">Why buy from me? I am a real person that you can call and talk to. I also use the product everyday, and will stand behind what I sell my name is Hugh Hudson and my number is 228-223-6207</FONT>
#1 #2
8000k start up on a 03 Cobra (CLICK HERE)
BI-Xenon 8000k SRT-4 (CLICK HERE)
12000k start up on a Linclon LS (CLICK HERE)
Please check out for your cars size
http://www.sylvania.com/Consum...t.htm
Available Bulb size :
<FONT COLOR="blue">H1, H3, H4, H7, H8, H9, H10, H11, H13,
880,881, 886, 889, 893, 894, 896, 898, 899,
9004, 9005, 9006, 9007, 9008, 9145, D1R, D1S, D2R, D2S.</FONT>
Available Color Temperature :
<FONT COLOR="red">3000K (Golden Yellow), 5000K(White), 6000K (White/blue) 8000K (Blue/white), 10000K (Blue/Blue),
(12000k Blue/purple)</FONT>
HID Bulbs
The HID bulbs are individually tested and engineered for maximum light output. Each bulb must pass a 200 hour endurance test, earthquake test, waterproof test, true color test, rapid on off test, and a max light output test. They have no equal. The estimated life spend for our HID bulb are about 3000 hours (approx. 5 year usage)
HID Ballasts
Our HID ballasts feature German hardware from Siemens and Japanese hardware from Panasonic. World class. Our HID ballasts also feature the separation of certain traditionally high failure components -- this custom assembly drastically decreases the failure rate. We know of no other ballast or HID manufacturer in the world which uses this very unique error reducing construction. Each HID ballast is individually tested and warranties for an industry defying 12 months.
Input voltage: DC 9-16V
• Input current: 3.5A
• Luminous flux: 3000
• Trigger voltage: 23KV
• Initial firing current: 8.5A
• Operate voltage: 85V +- 17V
• Bulb loading capacity: 35W
• Life: 3000 hours +
• Operate temp: -40~+105 C
Long Term Satisfaction
Don't cheat yourself with other HIDs. There is no guesswork when you buy your HID conversion kit from us -- you're buying a HID system with a warranty that defies an industry filled with degenerating knock offs.
What are HID Conversion Kits?
HID stands for "High Intensity Discharge". HID lights get their name from the intense light produced by the electrical discharge. HID Conversion Kits give you the option of installing true HID lights practically on any car that did not originally come with them.
What is the HID Color Temperature?
Color Temperature is a measurement in Degrees Kelvin that indicates the hue of a light source, in this case the HID bulb. People not familiar with lighting may believe that the higher the Kelvin the brighter the light will be, this is false. OEM car manufacturers equip their cars with 4100k to 4300k HID bulbs which produce the most daylight-like light output. Lower temperature like 3000k will produce deep gold-yellow color, suitable for fog lights. Higher color temperatures will output light with a hint of blue/purple like the 5000k - 6000k bulbs, higher rated bulbs will be bluer and eventually purple in color as you go up the scale.
Color temperature is what usually catches your eye when you spot an HID equipped car on the road. The Kelvin bulbs will appear "brighter" to oncoming traffic, but in reality they output less visible light onto the road.
Warranty & Return Policy
Each HID KIT has unique S/N. One Year Warranty, free for parts with S/N ONLY. (Always buyer's responsibility for shipping expense)!Be sure to keep the invoice for warranty purposes. No refund, exchange for defective item only! If you improperly install the kit (Includes defects resulting from water damage, fire, chemical spillage, acts of nature, misuse, abuse, neglect, alteration, modification, improper installation, submersion, vehicle crash, dropping or by any other type of impact), we cannot replace it.
<FONT COLOR="red">Feel free to PM, call, AIM or email me name is: Hugh Hudson
phone is: 228-223-6207 AIM:hughbie2002 email is: hughbie2002@gmail.com</FONT>
<FONT COLOR="red">Paypal is : hughbie2002@gmail.com If you are going to pay with paypal please add 4% to cover the fee
my hid kits are shipped VIA: USPS Priority Air Mail : 2-3 Business days
NOTE : upon payment, please notify me of your car's year, make and model in your PAYPAL PAYMENT.</FONT>
NOTE:
A special digital wire harness is needed for certain higher end types of car to by-pass the computer error message. (no additional cost)
Specially 2003 and newer Dodge, Chrysler, Mercedes-Benz, Jeep will definitely need special digital wire harness to function properly
please click on the pic's for slide show's
#1 #2
<FONT COLOR="cyan">Question? whats the difference in these HID Kits and
normal "aftermarket" lets say...silverstar bulbs?</FONT>
Answer.
HID stands for High Intensity Discharge. It refers to lighting technology that
relies on an electrical charge to ignite xenon gas contained in a sealed bulb. The technology of HID automotive lamps is similar to that of common vapor-filled street lamps. HID lighting doesn't have a filament but instead creates light by igniting an arc between two electrodes. HID lights get their name from the intense white light produced by the electrical discharge. HID lamps are also called xenon lamps, referring to a gas inside the lamps. HID general lighting has been used for years in sports arenas and stadiums around the country. [/color]
<FONT COLOR="#4000BF">This car has the top of the line silverstar bulb in the Pass side and my HID kit in the driver side </FONT>
<FONT COLOR="#FF8000">Other facts about HID's
Less power consumption than standard halogen.
Lasts up to 10X longer than standard halogen
3X the light output of standard halogen.
Improved down-road illumination.
Enhanced peripheral vision with hid headlights.
A higher color temperature.
</FONT>
Modified by hughbie2002 at 10:51 PM 3/18/2008
Modified by hughbie2002 at 10:52 PM 3/18/2008
Old Mar 18, 2008 | 07:01 PM
Default Re: HID's full plug and play kits $125 shipped 1 year Warranty (hughbie2002)
bumper up
Old Mar 18, 2008 | 09:39 PM
Kelb's Avatar
very intrested. Get paid this weekend, have to replace core support and bumper, will see if these fit my budget, id be investing in bi-xenon, shipped to 83501, For an EH3 (oem lights)
Thanks. Any pictures of the kit by a chance? How does installation work.
Old Mar 18, 2008 | 09:49 PM
Default Re: (Kelb)
pics and more info sent thanks alot hope to do bussiness with you soon
Hugh Hudson
Old Mar 19, 2008 | 03:58 AM
Default Re: (hughbie2002)
bump up
RGoose18
Sep 30, 2013 02:05 PM
operatic
May 15, 2009 06:40 AM
SLIPSTICK TIPPIN
Aug 13, 2007 05:43 PM
SLIPSTICK TIPPIN
Aug 10, 2007 04:19 AM
tunermarket
Mar 11, 2005 02:03 PM
