secondary o2 sensor question
Old Mar 18, 2008 | 12:31 PM
sohc vtec rex's Avatar
Default secondary o2 sensor question
hey h-t, i have a 96 civic coupe with the cel on, it is giving me number 65 which is the secondary oxygen sensor heater wire (black wires). i am wondering what i would have to do to fix it, do i just buy another o2 sensor or is it the cat? thanks in advance
Old Mar 18, 2008 | 12:35 PM
crazyguy's Avatar
Default Re: secondary o2 sensor question (sohc vtec rex)
o2 sensor is a wear and tear item so u cant fix it. simply buy a new one and replace it. ngk makes a good one. http://www.ngk.com
and secondary o2 sensor is the one on the cat convertor.
Old Mar 18, 2008 | 12:38 PM
Default Re: secondary o2 sensor question (crazyguy)
thanks, i just wasnt sure if it could be the cat that is making it faulty
Old Mar 18, 2008 | 12:50 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc vtec rex &raquo;</TD></TR><TR><TD CLASS="quote">thanks, i just wasnt sure if it could be the cat that is making it faulty</TD></TR></TABLE>
Usually when the cat goes bad, along with a rattle, you'll notice a decrease in performance/mileage
Old Mar 18, 2008 | 01:02 PM
thesmogman's Avatar
Also it code is for the heater circut. Not the signal. If it was the signal part then it could be the cat.
The heater circut is checkable with an ohm meter.
Old Mar 18, 2008 | 01:16 PM
Default Re: secondary o2 sensor question (thesmogman)
thanks a lot for the help guys
JDM-Vic
Apr 29, 2010 05:04 PM
TtOrMaMnY
Jul 4, 2008 12:56 PM
AllSpedup04
Oct 10, 2005 01:52 PM
cubism
Welding / Fabrication
Dec 1, 2004 10:39 AM
JoshRambo
May 15, 2003 07:16 PM
