Need help: if wilwood calipers will clear 15" enkei RPF1 +41 offset?
Old Mar 18, 2008 | 12:11 PM
x i b v r i a n's Avatar
Default Need help: if wilwood calipers will clear 15" enkei RPF1 +41 offset?
what's up guys,
im in a deal to buy 15x7 =41 offset enkei rpf1.
i have an 88 HF, right now it has SI front knuckles with 11" rotor and wilwood calipers.
Does anyone here on HT know for sure if the wheels will clear the wilwood calipers?
I've tried my friend's mugen rnr with the spec: 15x6.5 +45 offset, but the spokes hitting the calipers.
If anyone know, pls help soon.
Thanks guys
Old Mar 18, 2008 | 01:02 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Well I know i sold one of my customers an 11" kit for his crx w/ EM1 Si wheels.... the caliper needed no clearancing to fit them. FWIW i hope this helps.
Old Mar 18, 2008 | 01:58 PM
Default Re: (ComeOnKip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">Well I know i sold one of my customers an 11" kit for his crx w/ EM1 Si wheels.... the caliper needed no clearancing to fit them. FWIW i hope this helps.</TD></TR></TABLE>
Thanks for your info
I still need help from someone who experienced the same setup i try to run, or know someone who had it.
Old Mar 18, 2008 | 02:31 PM
SIred91's Avatar
Rainman
Default Re: (x i b v r i a n)
Yes, 15" RPF1's with 40mm will clear the Willwood setup.
Old Mar 19, 2008 | 11:35 AM
Default Re: (SIred91)
No they won't clear the wilwood calipers, i just tried them last night
But i picked up the enkei anyway cuz i liked them so much.
I'll use stock si front brake setup for now, till i find if i can use homemade big brake kit my friend told me about.
Old Apr 7, 2008 | 08:42 AM
nickrps's Avatar
NO, they will not fit. The biggest wilwood kit to fit under RPF1's is the 10.2 rotors. Unfortunately, the 11" rotors with the wilwoods limits you extensively on wheel selection.
Old Apr 7, 2008 | 11:38 AM
import2nr88's Avatar
I have the Fast brakes 11" rotor big brake kit that uses the DA calipers and they just fit. I had to shave the flashing off the caliper though and I might have a 1.5mm clearance from caliper to the back of the wheel spoke.
Hope this helps. If you use the ITR or Accord wagon calipers with the shaved mounting bracket they should fit.
Old Apr 7, 2008 | 12:32 PM
SIred91's Avatar
Rainman
Default Re: (import2nr88)
Damn man, sorry for telling you they would fit.....My buddies car has them, but they are 16's. sorry.
For what its worth, they fit under my 15 inch heliums with a 40 offset....
Old Apr 7, 2008 | 02:23 PM
ComeOnKip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Damn man, sorry for telling you they would fit.....My buddies car has them, but they are 16's. sorry.
For what its worth, they fit under my 15 inch heliums with a 40 offset....</TD></TR></TABLE>
BAN!!!!!!
highneo
Dec 9, 2008 01:49 PM
Hondacivic90ed
Nov 22, 2008 02:49 PM
juanchoenuncrx
Sep 25, 2007 04:26 PM
FakeJDMEF8
27
Aug 15, 2005 07:40 PM
FakeJDMEF8
Aug 9, 2005 12:24 PM
