Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rear brakes on H4 car
Old Mar 18, 2008 | 11:03 AM
sgallagher's Avatar
Default Rear brakes on H4 car
I have a 1990 honda civic hatchback dx. I am currently in the process of building it for H4. I was wondering if it were legal for me to replace the rear brakes with discs?
Old Mar 18, 2008 | 11:05 AM
thawley's Avatar
Default Re: Rear brakes on H4 car (sgallagher)
Did you look in the rule book?
http://www.nasaproracing.com/r...e.pdf
Old Mar 18, 2008 | 12:03 PM
sgallagher's Avatar
It is legal for me to call it a body swapped si, correct?Being removal of sunroof is legal and the car has no structural advantages.
Old Mar 18, 2008 | 03:34 PM
sgallagher's Avatar
Anybody?
Basically I want to make sure its cool to run a d16a6 in my dx.
Old Mar 18, 2008 | 03:36 PM
E-AT_me's Avatar
discs were never an option on 88-91 Civics. discs only came on 90-91 CRX's. so, unless you claim you are "bodyswapping" from a 90-91 CRX Si, uh. no.
as for the motor, as far as i know, yes. but i'm not sure what else you have to add to keep it legal. at that point i'm not sure exactly what distinguishes an Si from a DX..
Old Mar 18, 2008 | 03:45 PM
Lo-Buck EF's Avatar
Default Re: Rear brakes on H4 car (E-AT_me)
rear disc-no
to swap the engine and trans you also need to swap manifold and ecu to multiport (i dont know why you wouldnt)
Old Mar 18, 2008 | 10:38 PM
liquidoblivion's Avatar
I have had the same question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-AT_me &raquo;</TD></TR><TR><TD CLASS="quote">discs were never an option on 88-91 Civics. discs only came on 90-91 CRX's. so, unless you claim you are "bodyswapping" from a 90-91 CRX Si, uh. no.
as for the motor, as far as i know, yes. but i'm not sure what else you have to add to keep it legal. at that point i'm not sure exactly what distinguishes an Si from a DX.. </TD></TR></TABLE>
So get your facts straight. Rear discs came on both 90-91 Civic and CRX Si's.
Old Mar 19, 2008 | 02:02 AM
E-AT_me's Avatar
Default Re: Rear brakes on H4 car (liquidoblivion)
excuse me? are you talking to me? telling ME to get my facts straight? i drive a 91 Civic Si 110 miles a day, and it definately doesn't have discs in the rear. my 1990 CRX Si had discs in the rear.
Old Mar 19, 2008 | 05:30 AM
Lo-Buck EF's Avatar
yea, i have had 3 ef chassis, 2 si hatches. worked on numerous 90-91 civic si. none had rear disc. only crx.
Old Mar 19, 2008 | 08:29 AM
Default Re: Rear brakes on H4 car (Lo-Buck EF)
wow, heh, i guess I have just seen a ton of rear disc swapped hatchs. I figured the 90-91 civics came with rear disc like the CRX. Seems like someone told me I could use hatch Si e-brake cables when I did the rear discs on my sedan. Oh well that sucks, drums are such a pain to work on. I really want to build my civic into H4 but really didn't want to go back to drums.
Old Mar 19, 2008 | 08:33 AM
E-AT_me's Avatar
discs on sedans will push you out of H4, too. no sedan came with rear discs. EX w/d16a6 came with bigger front brakes though. still drums in the rear. EX also came with a few other "heavy" options..
btw, Si's have tilt steering. just another thing you've got to swap over to. i believe.
edit: read your post again. seems you know that discs on your sedan are illegal for H4. oh well!
side note: 88 Sedan DX for H5 here!! see it in 2 years time!
Old Mar 19, 2008 | 09:53 AM
Civic44's Avatar
I wouldn't worry too much about the rear drums. My first race car was a 1988 DX. I eventually swapped in a 125 hp SOHC vtec and the DX brakes coped just fine with the extra power on any track I visited. I just had Honda OEM shoes in them with braided steel lines and they were very low-maintenance. I believe I was running Hawk HP+ on most occasions for the front, on the OEM DX brakes.
Old Mar 20, 2008 | 07:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic44 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't worry too much about the rear drums. My first race car was a 1988 DX. I eventually swapped in a 125 hp SOHC vtec and the DX brakes coped just fine with the extra power on any track I visited. I just had Honda OEM shoes in them with braided steel lines and they were very low-maintenance. I believe I was running Hawk HP+ on most occasions for the front, on the OEM DX brakes.</TD></TR></TABLE>
Yea, im not too worried about braking power, drums always held up fine for me too on track. I did the swap just for ease of use, my drums I would have to manually adjust every month or so to keep the brake pedal firm and up top. I have the EX brakes on the front anyway, so braking shouldn't be an issue at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-AT_me &raquo;</TD></TR><TR><TD CLASS="quote">discs on sedans will push you out of H4, too. no sedan came with rear discs. EX w/d16a6 came with bigger front brakes though. still drums in the rear. EX also came with a few other "heavy" options..
side note: 88 Sedan DX for H5 here!! see it in 2 years time! </TD></TR></TABLE>
My DX has tilt steering, but even if it didn't, would that really be something you would have to worry about, having non-tilt steering doesn't really give you any advantage so it doesn't seem like that would keep one out of H4.
Old Mar 20, 2008 | 08:06 AM
E-AT_me's Avatar
i dunno if it would or not, all i know is my sedan doesn't have tilt but the Si i drive does. whatever. i wouldn't complain.
Old Mar 21, 2008 | 01:05 PM
sgallagher's Avatar
Thanks for all the info guys. I just picked up a 1990 hatch Auto that I am building for H4. I appreciate all the knowledge and experience you guys have and are willing to share on here.
I hope to see you guys in so. cal soon.
zccr-xsi
Oct 8, 2005 09:48 AM
88rexdxa6ed
18
Apr 17, 2003 07:30 PM
t o m
22
May 10, 2002 12:05 PM
Aahj
13
Mar 15, 2002 11:26 PM
FSTRex
21
May 8, 2001 09:33 AM
