Slow idle after timing belt change
Old Mar 18, 2008 | 09:33 AM
violarules's Avatar
Default Slow idle after timing belt change
I changed the timing and balancer belts on my 01 Accord VP (4 cyl.), and everything was lined up.
It runs fine, but it idles a little slower than it used to. It's not idling rough, there's no miss, and it doesn't shake upon acceleration as if the balance shaft is out of time, but it does idle slower.
Any thoughts?
Thanks
Old Mar 18, 2008 | 10:53 AM
jazzbass's Avatar
Default Re: Slow idle after timing belt change (violarules)
I recently did the same job on my sons 97.
The only thing I could think of is the timing was off by one tooth and you
corrected it, or your off one tooth which would account for a few degrees
timing change. Assuming nothing else was changed.
Meraut
May 8, 2013 09:43 AM
Schoust
Apr 21, 2013 04:48 AM
211811518
Sep 13, 2006 06:33 PM
spyderracing
Aug 27, 2004 08:39 AM
civicracer1993
Jan 24, 2003 07:48 PM
