The saga continues .. where is the main relay?
Old Jul 8, 2002 | 04:27 PM
slash00R's Avatar
New User
Default The saga continues .. where is the main relay?
For those that have helped me so far, thanks a bunch. Here is the story .. when my 90 crx wouldn't start I thought it might be the starter because the engine wasn't turning over. Starter is okay. Then I thought it might be the distributor. That is fine. Now with some suggestions and reading I've been listening for the tell tale click when you first turn the key to the ON position (which means the fuel pump is turning on for 2 seconds, then off again in order to build some fuel pressure). Sometimes I get the click, sometimes I don't ... I'm assuming now there is a problem with the main relay. When I get the click (indicating fuel pressure) the car will start, and when I hear no click, you got it, nada. I've read that you can take the main relay out and redo the soldered connections, but I can't seem to find the darn thing underneath the dash. I can hear the clicks put just can't place where it is exactly. Help!
Old Jul 8, 2002 | 04:45 PM
89civicdx's Avatar
Default Re: The saga continues .. where is the main relay? (slash00R)
driver side foot well above the hood opener lever
Old Jul 8, 2002 | 06:46 PM
SpoonPL's Avatar
Yup, just behind the hood lever opener switch.
PL
Old Jul 8, 2002 | 06:56 PM
dohcsideSi's Avatar
Default Re: The saga continues .. where is the main relay? (SpoonPL)
take the change tray out and you can see it...still have to get to it from the bottom though
Old Jul 10, 2002 | 09:26 AM
slash00R's Avatar
New User
Default Re: The saga continues .. where is the main relay? (dohcsideSi)
That thing is a bitch to take out .. anyone ever replaced one of these things? Did you repair yours or just replace it?
Old Jul 10, 2002 | 09:51 AM
Doodoo's Avatar
I replaced mine. It cost like $35 or so from the dealer. Cheap for a part that commonly goes out in our cars but should last another 10 years.
BTW it is a bitch to get at. I don't think I re-bolted mine up, just left it hanging.
Old Jul 10, 2002 | 02:19 PM
badCRX's Avatar
New User
Default Re: The saga continues .. where is the main relay? (Doodoo)
I had some of the same problems. I even took my starter out and had it tested and it past at an O'Reilly's and an Autozone. Still didn't work. I bought a '98 GSR one for my B16 and it started working. I guess since no load of the flywheel was on it the testers at those stores weren't that great of an indicator.
I'll probably buy a new main relay for the sake of not waiting til mine goes out.
Old Jul 10, 2002 | 04:09 PM
awake's Avatar
Just post your email address if you would like a good step by step w/ photos.
~Matt
Kidnkorner
Apr 4, 2010 08:54 PM
White98LS
Jul 14, 2007 07:46 AM
AgentJam
Aug 15, 2004 03:07 PM
Kasper.
Sep 25, 2002 07:26 PM
serious
Sep 2, 2002 05:38 PM
