2 recalls on my 07 sedan lx
Honda Motor Co., Ltd. has decided that a defect related to motor vehicle safety exists in certain 2006-07 model year Civic vehicles equipped with the anti-lock brake systems (ABS). The ABS module uses wheel speed sensors located on each wheel hub assembly. Some wheel sensors may have been improperly installed and do not seal the hub assembly. Water may enter the hub assembly and damage the wheel bearing. In areas where road salt is used, the wheel bearings may corrode even more quickly, which may cause the wheel to separate and fall off, increasing the risk of a crash.
Honda Motor Co., Ltd. has decided that a defect related to motor vehicle safety exists in certain 2006 model year Civics. During vehicle assembly, the telescopic steering column mechanism may have been over-lubricated with silicone grease. Over time, some of this extra grease may drip on the brake light switch and the brake light switch may fail. Failure may result in a loss of brake lights and an increased risk that your vehicle could be struck from the rear. In addition, a failed brake light switch could prevent shifting the transmission from the park position (applies to vehicles with an automatic transmission).
Jriddlez
Jan 29, 2013 06:37 AM
HondaJon
Honda Civic (2006 - 2015)
Oct 6, 2008 11:28 AM
