cable transmission lever not returing.
Old Mar 17, 2008 | 07:24 PM
joonguyen's Avatar
Default cable transmission lever not returing.
As stated above i have a 93 ls cable tranny and recently my lever stop returning all the way up. At first, i thought that it was my transmission cable. i replaced the cable with no luck. my clutch pedal has about an inch of travel. visibly i can see that the lever is not fully returning as it should. my question is it worth trying to fix the lever? or to invest in another transmission? thanks for the help.
Old Mar 17, 2008 | 10:56 PM
LoseRPunKx182's Avatar
Default Re: cable transmission lever not returing. (joonguyen)
u should make sure the tb clip is still attached, it can be the cause of ur problem and is a cheap part to fix.
turbo-crx
Oct 7, 2008 02:45 PM
EKIM NART
Mar 12, 2006 06:06 PM
GSR 91 crxsi
Feb 19, 2006 05:30 PM
BrokenRex
Nov 23, 2005 03:39 PM
