Help! *Major* Problem after Timing belt install...Did I mess Up My DD???!?!?
ok i changed the timing belt and water pump, put everything back together and started her up...loud noise from the head(i think) happens immediately and the header gets hot after 1 minute and light smoke comes from the exhaust side which smells like celery ha...all cam marks and crankshaft marks were lined up perfectly....
here is a video of whats going on; i revvedit up after a minute-all help is appreciated!
http://www.youtube.com/watch?v=kxHvN16Y3Bc
*excuse me while i look for a new car*
Modified by lmike6453 at 9:02 PM 3/17/2008
yea but i'm also running it with a gsr timing belt only difference is 3 teeth...do you think that i bent a valve....
for instance, what happens if you spin the crankshaft without the spark plugs removed and cams not attached??
the gsr timing belt is not only longer because of the the water pump but also for the location of the cams. the cams in a vtec head sits higher than the non-vtec head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">yea but i'm also running it with a gsr timing belt only difference is 3 teeth...do you think that i bent a valve....
for instance, what happens if you spin the crankshaft without the spark plugs removed and cams not attached??</TD></TR></TABLE>
you gonna have to start over with the right parts and do a comp test to find out
i dont know for a fact that it wont work.
but i do know there's a difference between the pumps, head heights, and belts
there's also an order the belt goes on. it's super hard to get it on if you dont follow the order
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">because the water pump spins less at high rpms</TD></TR></TABLE>
That was a very uneccessary mod. Swapping a LS water pump should be the least of your concerns.
yea but what i don't understand is how people put it on their ls/vtec and everything is fine...why would it be different in my situation? i even torqued the bolts down to 16 ft lbs...
if you're going to say the cam height i don't think so cause it barely fit on with the teeth lined up....
and i didn't have any white smoke come out the exhaust...
please help h-t i need you now more than ever...watch the vid and let me know
oh dude i just watched the video you definetly bent the valves i think there hitting each other just find another head and no im not just trying to sell you a head i dont have one for sale i just know that sound and you probably still have compression its out of time and the intake valves are hitting the exhaust valves but if you can change the timing belt you can change the head the belt is the hardest part
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">yea but what i don't understand is how people put it on their ls/vtec and everything is fine...why would it be different in my situation? i even torqued the bolts down to 16 ft lbs...
please help h-t i need you now more than ever...watch the vid and let me know</TD></TR></TABLE>
they did help you, and told you what you needed to fix. You have the wrong pump and belt.
Yeah, it's not sounding good there buddy.
A good word of advice is to always turn the engine over by hand before you crank it. I tightened my timing belt recently and did just that: Turn it over by the bolt on the crank pulley a couple times to make sure all was well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">yea but i'm also running it with a gsr timing belt only difference is 3 teeth...do you think that i bent a valve....</TD></TR></TABLE>
Double check that your timing is good and get the correct timing belt plz.
3 Teeth is alot.. 1 tooth is ALOT. Only the correct timing belt is acceptable buddy. I do believe you probably just cost yourself a new head. If your cam timing is dead on 100%: Yank the head and look at the valves.
But hey, look on the bright side! You can guy a GSR/B16 head and do an LS-Vtec now
i understand what you're saying about the teeth difference but i thought it was an even trade as far as...22 vs 19 teeth on the pump and 3 extra teeth on the belt...
wow this really blows...i have to remove the head just to check...
if anyone else has any advice please feel free to post or as soon as i remove the head i will post pictures to get more advice from you guys...
thanks for the help-cheers
the extra teeth on the pump and the belt is what makes up the height difference on the vtec head the valves are hitting each other sorry to keep giving you bad news maybe if you get the ls belt and pump it will run ok but i think you would be wasting your time and theres probably some coolant on the outside of the block somewhere thats burning off
