No Fuel/No Power to Pump
Old Mar 17, 2008 | 03:47 PM
ShawnS4363's Avatar
Default No Fuel/No Power to Pump
So I am the new owner of a '93 Civic DX 1.5L. It was running when I got but it got to the point that it doesn't start now.
I had already planned on replacing the fuel pump and when I went to do that today I noticed the pump wasn't getting any power to turn on. Someone had told me that the MAP sensor isn't turning on the pump?
My question: Is what I have been told correct or do I need to look in other places to solve this. A new map sensor is like $250.
Thanks for the help.
Old Mar 17, 2008 | 04:05 PM
Sr420Det's Avatar
Map has nothing to do with it try your main relay.
Old Mar 17, 2008 | 04:08 PM
EG8R's Avatar
Default Re: (Sr420Det)
Main relay (Y)
Old Mar 17, 2008 | 04:19 PM
Sr420Det's Avatar
Cause it controls your fuel pump thats Y
Old Mar 17, 2008 | 04:49 PM
ShawnS4363's Avatar
Where would that relay be located?
Old Mar 17, 2008 | 04:52 PM
Chiovnidca's Avatar
Default Re: (ShawnS4363)
Dont forget to check fuses.
Old Mar 17, 2008 | 05:13 PM
Sr420Det's Avatar
Its under the steering wheel behind the fuse box it says main relay and should be held up by one bolt. Try swaping it with a friend first to see if that fixes the problem.
Old Mar 17, 2008 | 05:48 PM
ShawnS4363's Avatar
Cool thanks for the info..I will have to check it out tomorrow.
Old Mar 18, 2008 | 07:16 PM
EG8R's Avatar
Oh haha Oops I meant to put the heh (Y) is for msn messenger thingy heh
Old Mar 20, 2008 | 04:25 PM
ShawnS4363's Avatar
Hey Sr420Det.. Thanks for the advice! I swapped out the fuel pump and that relay and the car started right up.
I do have one more question though...its idling too low and I was wondering how to idle it up?
Thanks!
jerome^galon
Jan 6, 2012 08:48 AM
92hatch!
Dec 10, 2009 12:35 PM
gsrt nick
Oct 23, 2006 06:43 PM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
insomniac791
Jan 22, 2004 04:23 PM
