Whats the best ECU to swap into a 91 civic hatch? Rough idle.
Old Mar 17, 2008 | 01:55 PM
91civiczcswap's Avatar
Default Whats the best ECU to swap into a 91 civic hatch? Rough idle.
I have a 91 Civic hatch with a ZC DOHC 1.6 L engine in it and i just wanted to know whats the best ECU to swap into it.
My car is also running real rough and when i put it into neutral from high rpms (above 2000 rpms) my idle drops down to about 200 and wants to die most of the time. i've changed the distributor cap, rotor, spark plugs, wires, fuel filter, and the coolent temp sensor. It runs way rich and i get about 125 miles to a tank.
Any ideas because im stuck and i dont know what else it could be. Maybe a wiring harness. If you have any info on either topic please let me know. i could use the help.
Old Mar 17, 2008 | 02:20 PM
ktp1598's Avatar
Get a computer from a 1989 acura integra 5 speed. PG7 I think. If you have an Si computer and wired it up right, it's probably a bad sensor. Double check your wiring. It's always the simple things.
Old Mar 18, 2008 | 08:04 PM
Default Re: (ktp1598)
the 89 teg would fit the zc motor rite? but yah thats ill double check all my sensors and see whats up with them. thanks guy
Old Mar 18, 2008 | 09:01 PM
traxxasx's Avatar
check ur ecu see if its throwing any codes.
Sounds like a bad 02 sensor.
Old Mar 18, 2008 | 09:06 PM
Default Re: (traxxasx)
my ecu does throw codes. i havent got it checked out yet but about 15-30 minutes of driving my check engine light then turns on.
Craig Hobbs
Jun 17, 2019 11:27 AM
jrhcivak
14
Jul 24, 2012 05:06 PM
Beeean
13
Feb 18, 2012 04:56 PM
91blackcivicsi
Feb 13, 2010 04:03 PM
mac_24_seven
14
Sep 26, 2007 08:25 AM
