? about the fuse box
i have had this problem for awhile and the people at the dealership said that it had nothing to do with the box but in getting power from the input side and not the output side thanks for the help
Its pretty easy to open it up. pull the taps back on each side and pry it open carefully. Then you can visualy inspect it and possibly even repair it,
look here>http://www.g2ic.com/forums/showthread.php?t=127170
I had a intermittent wiper problem with my ICM and I ended up unplugging it and inspecting it. it looked perfect inside, so I snaped it back together and plugged it in, and it worked again.
bad connection maybe?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by battle355 »</TD></TR><TR><TD CLASS="quote">but in getting power from the input side and not the output side thanks for the help</TD></TR></TABLE>
are you using a wiring diagram for that?
Also what is your root problem? is it with the front lights, or all parking lights?
bad connection maybe?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by battle355 »</TD></TR><TR><TD CLASS="quote">but in getting power from the input side and not the output side thanks for the help</TD></TR></TABLE>
