DA itr swap help
I want to put my ITR engine and trans into my 92 DA. i have a whole DC2 parts car that i can take stuff from. so my question is-
-Can i use the mounting brackets in my DA for the ITR engine, or does it have to be modified for the hydro tranny?
-can i use the axles from my DC2?
-what has to be done with the Vss if i keep the hydro tranny?
Thanks so much,
Brandon
Thanks so much,
Brandon
my computer got hacket and i cant get on there anymore, that sucks to cuz i have 3 da's lol
i dont know how to get a new ip address
You can use the b18a1 mounts on the b18c5, except for the tranny. You can also use the cable speed sensor off the ys1 tranny and bolt it into the itr tranny. you will, however, need to either get a cable to hydro conversion assembly (i recommend the innovative mounts piece). as far as the hydro tranny mount, you can buy one from hasport or innovative mounts or make your own, like i did.
https://honda-tech.com/zerothread?id=2234565
good luck!
good luck!
if i can actully get a real picture of what you did to make it work.
i wanna make my own, i have a full dc2 parts car.
as hydro goes im taking the pedals and mc out and using it in the da
Heavy Pee
Jan 11, 2005 05:04 PM
lastlude2k1se
Oct 13, 2004 09:17 AM
