HELP!! oil leaking from under dizzy
Old Mar 17, 2008 | 11:18 AM
xYoung s15's Avatar
Default HELP!! oil leaking from under dizzy
alright honda tech. i've been trying to find out where the hell the leakage is coming from and i cant seem to figure it out.
replaced:
dizzy O-ring
valve cover gasket
and still leaking..it seems to be coming from underneath the distrubitor but i already replaced the o-ring..could i have put it on wrong? it seemed easy enough, off with the old and on with the new.
im getting really fustrated and any help is appreciated. i hope its not my head gasket...i will post pics soon. in the mean time, any idea??
Old Mar 17, 2008 | 05:49 PM
slammedvtec's Avatar
Default Re: HELP!! oil leaking from under dizzy (xYoung s15)
i know this sounds dumb but i had the same problem on my b16, i had to replace the oring three times before i got one to work, make sure you get your o ring from honda. if its not that head gasket would be my next guess. any oil in your coolant? any signs of overheating? by the way i recommend that all honda owners get a water temp gauge i just got one and that stock piece of **** doesnt move from 140 degrees F to 210 degrees F its bull ****
Old Mar 17, 2008 | 06:49 PM
z6hatchboy's Avatar
look right under the dizzy, if coming out of the hole the dizzy shaft goes in then its deff the o-ring. You can also take the dizzy cap off, sometimes they leak from inside, mine did recently and went down the block and such.
Old Mar 17, 2008 | 06:55 PM
egsleepercivic's Avatar
make sure you coat the o ring with non synthetic oil before you install
gl
Old Mar 21, 2008 | 11:11 AM
xYoung s15's Avatar
Default Re: (egsleepercivic)
damn..now that i think about it. i didnt lube the o-ring
let me oil the sucker up n see if it helps..
thanks guys..hopefully this will do the trick.
dc2_dude
Feb 13, 2009 12:12 AM
Teddymiester
Honda Civic (2001 - 2005)
Nov 4, 2008 09:34 PM
caminSi
Jul 27, 2006 07:52 AM
ECKOTYPER
Jan 28, 2004 01:17 PM
Monty
Oct 7, 2002 02:51 PM
