88' dx auto to manual! swapped cluster problems???
Old Mar 17, 2008 | 10:52 AM
CR-V-tech's Avatar
Default 88' dx auto to manual! swapped cluster problems???
ok guys i know that this is a pretty common thing but cant find any good info on this, the FAQs cluster swap wont pull up a web page, and i did a few searches and came up empty handed!
ok here is the scoop, i did an auto to man on my buddy's 88 dx 4dr, and i had an 89 si cluster laying around, i swapped it in and the tach didn't work and the oil psi light stayed lit dimmly even when the car was turned off! it's obviously something to do with the pin-outs to the cluster, does anyone have the correct info to correct my problems and make the tach work??
any info is greatly appreciated, thanks in advance
Old Mar 17, 2008 | 05:34 PM
ef_junky's Avatar
Default Re: 88' dx auto to manual! swapped cluster problems??? (CR-V-tech)
i've got a 90 lx and iwent to swap an 88 si cluster in today and yep same problem oil pressure light is on when low beams are on battery light is always on and the check engine light comes on when i turn the high beams are one i'm going to try and figure something out and i'll let you know
Old Mar 18, 2008 | 05:34 PM
KillerED3's Avatar
The 88-89 clusters are different from the 90-91 clusters. Make sure you have the right one.
Old Mar 19, 2008 | 06:03 PM
CR-V-tech's Avatar
Default Re: 88' dx auto to manual! swapped cluster problems??? (KillerED3)
the car is an early build 88' and the cluster is for sure an 88-89 cause i tried to put into my 91 hatch and it wouldn't fit! thanks again guys, any more info would help!
Old Mar 20, 2008 | 09:00 AM
CR-V-tech's Avatar
bump for more info
Old Mar 24, 2008 | 02:30 PM
CR-V-tech's Avatar
bump again
Old Mar 25, 2008 | 07:32 AM
CR-V-tech's Avatar
bump for more info
Old Mar 25, 2008 | 07:36 AM
BrentonJ's Avatar
https://honda-tech.com/zerothread?id=1507337
Some info there. I think those were the right years your were looking at. I'm trying to find easier pictures to use.
Old Mar 26, 2008 | 07:32 PM
CR-V-tech's Avatar
Default Re: (BrentonJ)
bump for better info
Old Mar 26, 2008 | 07:42 PM
SoCal B18b 4dr's Avatar
if teh car is an 88, then u need an 88 cluster, some will say 88 and 89 is the same, but that doesnt always hold true. i have a 89 cluster sitting here that doesnt work in my buddy 88, the engine harness even look different. i think it is depending on where the car was made, but this 89 i stuff i have here isnt the same as the 88, some 88's have only 1 set of plugs in the engine bay for the harness (meaning no plugs for the engine harness on the driver side next to the resistor box). u can rewire the 90-91 to work in the 88, there is a diagram to do so floating around on this site... i have this link here, hopefully i dont get in trouble for linking off site http://crxcommunity.com/viewtopic.php?p=65118
Old Mar 26, 2008 | 08:11 PM
CR-V-tech's Avatar
Default Re: (SoCal B18b 4dr)
hey man thanks alot
hondadx
Apr 11, 2008 02:21 PM
StupidSlowRSX
39
Aug 14, 2007 01:24 PM
dohdoh420
May 1, 2005 09:11 PM
pK1spooled
Oct 2, 2004 01:24 PM
Hawd
Jul 24, 2002 11:52 AM
