Head Gasket install error... warping risk?
Old Mar 17, 2008 | 10:13 AM
RNbuilt's Avatar
Default Head Gasket install error... warping risk?
how big of a risk is it for the head and block to get warped with a bad HG install? the car has never overheated, but definitely a leak due to coolant consumption. the car also drives fine.
Old Mar 17, 2008 | 10:50 AM
citrus3000psi's Avatar
Default Re: Head Gasket install error... warping risk? (RNbuilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNbuilt &raquo;</TD></TR><TR><TD CLASS="quote">how big of a risk is it for the head and block to get warped with a bad HG install? the car has never overheated, but definitely a leak due to coolant consumption. the car also drives fine.</TD></TR></TABLE>
No it shouldn't but that doesn't mean its not possible. If it was me I would take the head back off and just put a new gasket on. I would be doing the labor, so no money loss. If it contiunes to leak after the new gasket then yes its more then likely warped.
It doesn't cost much take to long to have a machine shop check it but if you don't want to check then just put another gasket on and hope for the best.
Oh theres no need to make a new thread for this. Since you already started one.
Old Mar 17, 2008 | 11:25 AM
CW-ITR's Avatar
Default Re: Head Gasket install error... warping risk? (citrus3000psi)
X2
Magic Wheels
Sep 30, 2007 12:04 PM
d16y8EL
Mar 29, 2007 06:55 PM
ReGMiLLa31
Honda S2000
Aug 16, 2006 07:16 AM
braintree
Aug 12, 2006 04:54 PM
InTeGrA B18b1
Apr 7, 2005 04:08 PM
