Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Phil's tire service specs/suggestions for camber/caster with RA1s
Old Mar 17, 2008 | 10:05 AM
Justin Jones's Avatar
Default Phil's tire service specs/suggestions for camber/caster with RA1s
Would you guys agree or disagree with these sugestions:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil's Tire Service &raquo;</TD></TR><TR><TD CLASS="quote">Caster:
As much as possible (very difficult with stock vehicles).
Camber:
Negative 2.5 to negative 5.0 deg. acceptable. anything lower than 2.5 or higher than 5.0 deg. negative will create some irregular wear.
So according to this, if we're running RA1s (or R888s/NT01s as well i suppose since they allegedly have the exact same compound) we EG/DC2, etc.. owners should definitely swap our front UCAs left to right and right to left to gain us caster (apparently that swap is good for 3 degrees caster roughly.) As well as anything else that increases the caster angle... I'm weary of adding anything more than the 3 degrees from the left-right swap due to having an integra steering rack with PS seals removed in my Civic...
Also, I was searching some more for Caster/R comp threads and came upon this interesting quote in regards to the RTR/tri-point cars on spec RA1s in 2005...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RR98ITR &raquo;</TD></TR><TR><TD CLASS="quote">
Scott, who saw lots of caster on RTR and Tri-Point cars in 2005... and surely they think they know something...or at the very least they think something...how bout this: there's no apparent dynamic Negative associated with running 6-7 degrees...</TD></TR></TABLE>
Old Mar 17, 2008 | 11:58 AM
granracing's Avatar
I'd give Phil a call and see what he has to say. As much as possible probably means as much as possible with a stock vehicle / set-up.
blinger
Oct 18, 2007 06:36 AM
Delano5050
Suspension & Brakes
Aug 4, 2007 07:30 PM
accordredliner
Oct 3, 2005 04:57 AM
rice a roni
Suspension & Brakes
Sep 27, 2005 01:52 PM
xXx Justin xXx
12
Feb 12, 2004 07:51 PM
