Why do I have oil around my spark plugs?
your oil rings are proly starting to go bad alowing excess oil to make its way up into the cylinders, or your valve seals are bad thats a little easier to notice as when you first start up your car it smokes like a chimmney. Both commom with older integras
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegra07 »</TD></TR><TR><TD CLASS="quote">Its not smoking like a chimmney. So its o rings? Is that easy to replace? How much are they at the dealer?</TD></TR></TABLE>
o rings are very easy to change. just remove the spark plugs wire, and a few nuts to remove to take out valve cover and u will see o rings. and it will be #7 shown in the pic and it cost around $2.25 each at most. but since remove valve cover, chances are, u might need to replace valve cover gasket too which is around $10
hey thanks for the illustration. Do I still need to change my gasket if its a year old? And if if do need to change it, what sealant stuff to use at each corner? I forgot what i put down last year.
Ohh and what web site is that illustration? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegra07 »</TD></TR><TR><TD CLASS="quote">hey thanks for the illustration. (1)Do I still need to change my gasket if its a year old? And if if do need to change it, what sealant stuff to use at each corner? I forgot what i put down last year.
(2)Ohh and what web site is that illustration? thanks</TD></TR></TABLE>
(1)Personally I change the VC gasket every time I take off the VC
(2) http://www.hondapartsunlimited.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK 2 9K »</TD></TR><TR><TD CLASS="quote">use hondabond! that **** works wonders on ANYTHING</TD></TR></TABLE>
Still leaking guys but not as bad. I changed out with new o rings. Made sure the valve cover was clean of old oil. What else to check?
could be oil seeping up from the crank case via bad piston rings...try a compression check.. but if its not your valve seals or your gaskets/grommets...
could get expensive
could get expensive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegra07 »</TD></TR><TR><TD CLASS="quote">Still leaking guys but not as bad. I changed out with new o rings. Made sure the valve cover was clean of old oil. What else to check?</TD></TR></TABLE>
weird
weird
dismemberment
Feb 18, 2009 02:51 PM
7rrivera7
Dec 21, 2003 03:47 PM
dohc_Cx
Aug 28, 2001 11:33 AM
