CAR NOT STARTING!! please help!
Old Mar 16, 2008 | 05:31 PM
dumada9's Avatar
Default CAR NOT STARTING!! please help!
hey went out side to start my car this morning and it wouldnt start up. battery is good, fuel filter is good, starter is good, i listened for my fuel pump and it sounded very quiet, i could barely hear it load. any ideas?
Old Mar 16, 2008 | 06:48 PM
TRuST's Avatar
Default Re: CAR NOT STARTING!! please help! (dumada9)
If the starter is good then my next guess would be the ignitor. Those go bad all the time.
Old Mar 16, 2008 | 06:53 PM
EF_9's Avatar
same thing for my brother hes changing out his main relay hopefully thats it
Old Mar 16, 2008 | 06:56 PM
95_B18b1_Teg's Avatar
good luck dood i was thinking it was the starter till i read it was good
try the ignitor
matmcg's Avatar
stick a screwdiver in your plug wires and see if there is spark by getting someone to look while turning th e car over
If no spark then check at the begining of the cap
if yes its ur wires
If not then it is ur ignitition coil
Old Mar 16, 2008 | 07:00 PM
dumada9's Avatar
Default Re: (EF_9)
the starter seems to be completely good, never had any problems. im hoping that either the fuel pump is too weak to pump, or its just the main relay. how much did the main relay cost?
Old Mar 16, 2008 | 07:03 PM
dumada9's Avatar
Default Re: (dumada9)
theres so many things that could be causing this problem its ridiculous =\. do you guys think that maybe because the fuel pump is so quiet compared to all the other cars i've heard it doesnt have enough power to pump the fuel, i was thinking of pulling the spark plug to see if theres any gas on it, if there is i can rule out the main relay and fuel pump
Old Mar 16, 2008 | 07:10 PM
jbecke2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_B18b1_Teg &raquo;</TD></TR><TR><TD CLASS="quote">good luck dood i was thinking it was the starter till i read it was good
try the ignitor</TD></TR></TABLE>
x2... check for spark, its probably a coil or something along those lines
Do you hear the fuel pump run when you turn the key to the ON position (not start position) if you hear it odds are its OK
Old Mar 16, 2008 | 07:49 PM
dumada9's Avatar
Default Re: (jbecke2)
i could hear it BARELY, when i compare it to my girlfriends car and my friends car, theirs are alot louder, iono if that makes a difference
Old Mar 16, 2008 | 08:53 PM
matmcg's Avatar
does it crank?
Old Mar 16, 2008 | 09:52 PM
dumada9's Avatar
Default Re: (matmcg)
yeah it cranks just wont actually completely turn over, but you can hear it cranking though
Old Mar 17, 2008 | 05:03 AM
matmcg's Avatar
I had the exact same problem
I could hear the fuel pump
Main relay clicked and was fine
Starter was fine , it ended up being my ignition coil , BUT TEST THIS BEFORE YOU GO OUT AND BUY A NEW ONE
Old Mar 17, 2008 | 06:52 AM
j_bizach's Avatar
I believe i got a used one still laying around out of my 93 ls
Old Mar 17, 2008 | 11:22 AM
matmcg's Avatar
swap it in and test it out!
Old Mar 17, 2008 | 11:45 AM
cowboys22cardinals22's Avatar
* B A N N E D *
EVEN TRY RETARDING THE DISTRIBUTOR... EVERYTHIGN THAT YOUR SAYING CHECKED OUT FINE ON MY TEG... AND WHEN I RETARED THE DISTRIBUTOR SHE FIRED RIGHT UP... SO THEN I DID NEW TIMING BELT AND WATER PUMP
Joharra12
Nov 10, 2012 08:50 AM
97civic07gsxr
21
Feb 8, 2009 02:33 PM
allmotor2.1
Nov 21, 2007 05:45 AM
JDMdamian95
12
May 6, 2006 08:37 PM
Spooled1.6L
Apr 20, 2004 05:49 AM
