car just stoped, B16A2 1996 Del sol Vtec
Old Mar 16, 2008 | 01:47 PM
B00M3R's Avatar
Default car just stoped, B16A2 1996 Del sol Vtec
Hye guys I had a problem with my sol and thought maybe you could help me out. i will give you as much info as posible and if you could tell me what you think i would do, I would apreciare it.
couple of days ago i was driving to work, I started my car and warmed it up before i left, I made it about a mile and stoped at a light.
The car idoled fine and didnt give me any cause for alarm. When the light went green I accelerated into the street made it about 15 feet then the engine just stright up died. I was rolling so i pushed in the clutch and tried to start it again but it would just crank. I got out of the street and into a parking lot and checked all my wires, everything looks good.
when i turn the key I can hear the fuel pump prime, but when I try and start it, it just crankes. I pulled out the ignitor and replaced it with a new one and verified it got spark. To get to the Distributor i pulled out the intake.
When i am cranking it i can smeall gas so it should be geting some.
What would you sujest I check next? any ideas?
Thanks
Old Mar 16, 2008 | 01:51 PM
crazyguy's Avatar
Default Re: car just stoped, B16A2 1996 Del sol Vtec (B00M3R)
do u get any fuel to injectors and any sparks?
Old Mar 16, 2008 | 01:53 PM
B00M3R's Avatar
Default Re: car just stoped, B16A2 1996 Del sol Vtec (crazyguy)
I have verified spark, and can smell fuel but not sure how to test fuel better.
Old Mar 16, 2008 | 01:55 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00M3R &raquo;</TD></TR><TR><TD CLASS="quote">I have verified spark, and can smell fuel but not sure how to test fuel better.</TD></TR></TABLE>
i mean if one of the injectors is shot, the car can still fires up but will run very rough, and in your situation, the car wont even fries up. i meant to say check the fuel line to fuel rail. and also check all the fuese and main relay and starter. make sure all the ground wires are good.
Old Mar 16, 2008 | 02:06 PM
B00M3R's Avatar
checking relay now, and I have verified all fuses.
what is the best way to test a fuel rail, crack the banjo bolt and see if it leaks?
Old Mar 16, 2008 | 02:11 PM
egsleepercivic's Avatar
how old is your timing Belt ?
Old Mar 16, 2008 | 02:15 PM
B00M3R's Avatar
Default Re: (egsleepercivic)
I was told it was replaced before I bought the car.
my guess would be 15000 miles maybe.
Old Mar 16, 2008 | 02:18 PM
B00M3R's Avatar
Default Re: (B00M3R)
I am trying to verify my main relay but the pics a friend told me to look at to see what they look like are diffrent then the ones I found.
can anyone verify this is the main relay?
Old Mar 16, 2008 | 02:43 PM
B00M3R's Avatar
found the main relay, was looking under the hood not in the car.
I swaped it out with the one from my civic (same part numbers) and it still did the same thing.
Old Mar 16, 2008 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00M3R &raquo;</TD></TR><TR><TD CLASS="quote">I was told it was replaced before I bought the car.
my guess would be 15000 miles maybe.</TD></TR></TABLE>
people say a lot of things, just check to make sure its still intact before you rip the car apart looking for other things
Old Mar 16, 2008 | 04:34 PM
B00M3R's Avatar
just replaced the fuel presure regulator with the stock one. when i loosened the bolts it leake4d fuel so i think we have fuel to the rail.
Old Mar 16, 2008 | 06:43 PM
superfast666's Avatar
check for spark check for fuel (make sure the injectors are actually working) check compression
Old Mar 17, 2008 | 08:04 AM
mrspeedy69's Avatar
My old del sol did that once and all it was, was the distributor.
Old Mar 17, 2008 | 08:37 AM
CTRwannaB's Avatar
Default Re: car just stoped, B16A2 1996 Del sol Vtec (mrspeedy69)
Since you already did all that I would just check for compression and timing.
I bet you jumped a tooth or the belt broke
I hoping it not the later.
Old Mar 17, 2008 | 12:40 PM
packman5280's Avatar
if the belt is broke, it will crank really fast and sound higher pitched than normal.
Old Mar 17, 2008 | 12:48 PM
93blacksol4life's Avatar
It's the distributor gone i had the same thing go on my sol with a B16.
Old Mar 17, 2008 | 01:21 PM
slammedvtec's Avatar
Default Re: car just stoped, B16A2 1996 Del sol Vtec (93blacksol4life)
i agree distributor or timing belt, the way i checked my injectors is the ghetto way.. take out the rail with the injectors and point the rail out fo the engine bay and do it outside, get somone to crank it over a couple times your injectors should spray
Old Mar 17, 2008 | 01:29 PM
Default Re: car just stoped, B16A2 1996 Del sol Vtec (slammedvtec)
even if it is the timing it will still start
Old Mar 17, 2008 | 02:26 PM
if the timing belt broke, there is no way the motor will run. how would the valves open and close?
Old Mar 17, 2008 | 02:28 PM
acright20's Avatar
Default Re: car just stoped, B16A2 1996 Del sol Vtec (superfast666)
i had the same prob on my 4 door my gsr jus stoped it ended up being the timing belt
Old Mar 19, 2008 | 07:06 PM
B00M3R's Avatar
Anyone have a OBD2 B126 distributor for sale?
Old Mar 19, 2008 | 07:38 PM
yoffer's Avatar
Banned
I have money on the ignition coil. Happened to me and two other friends on mine. Car just died and kept cranking.
Old Mar 20, 2008 | 02:48 AM
newby_j's Avatar
Needs More Cowbell
I am also thinking that it is the belt.
Old Mar 20, 2008 | 03:37 AM
barryEK4's Avatar
Distributer 100%
Old Mar 20, 2008 | 06:49 AM
nasteboyii's Avatar
50/50 coudl go either way dizzy or timing belt
easy way to find out
pull off timing belt top cover
see if belt is tight, and not shreaded or anything
if its cool, turn to tdc and make sure thye all line up and didnt jump
if it did not jump then dizzy
good luck
d
