ok to run 5w-30 in base?
Old Mar 16, 2008 | 12:14 PM
rnepmc077's Avatar
Default ok to run 5w-30 in base?
like the title says, is it ok to run 5w-30 in a base model rsx? being summer time(soon) in texas im wondering if my engine will take kindly to the added viscosity.
Old Mar 16, 2008 | 01:13 PM
Perfectionist's Avatar
Default Re: ok to run 5w-30 in base? (rnepmc077)
I wouldn't worry about a slightly higher viscosity in warmer temps. Higher viscosity in low temps might not be so good, though.
I assume your manual recomends 5W-20? If so, 5W-30 isn't going to hurt it. The lower viscosity is mainly to achieve a slightly higher MPG on a cold engine in my opinion. If your car is still under warranty, I would suggest you follow what the manual recomends. There's less chance of having problems with warranty claims for engine problems.
Old Mar 16, 2008 | 02:41 PM
madcityEP's Avatar
I run royal purple 5-30 in my EP, same motor you should be ok.
Old Mar 16, 2008 | 06:19 PM
square_1's Avatar
Default Re: ok to run 5w-30 in base? (madcityEP)
Viscosity won't matter and they can't void a warranty for putting synthetic or different viscosity in there.
I called the dealer on it and they just sat there and told me over and over they don't recommend it but I got them to admit it won't void the warranty after like 5 minutes...
No reason it should. It's oil. I lubricates...
Old Mar 16, 2008 | 11:12 PM
johnclaunch's Avatar
Default Re: ok to run 5w-30 in base? (square_1)
Just don't use 20W50.
Old Mar 18, 2008 | 06:05 PM
square_1's Avatar
Default Re: ok to run 5w-30 in base? (johnclaunch)
^ Yeah. That too...
lsturbo*
14
Nov 2, 2012 05:08 PM
Hanmin
May 29, 2008 03:03 PM
rewerbcrx
Nov 13, 2007 02:00 PM
oshkosh
Jul 18, 2006 08:44 AM
siisgood00
13
Sep 18, 2001 04:30 PM
