f.s h22a lsd swap low miles
97 jdm h22a swap only 800miles on it
hasport mounts for an eg
pasenger axle is raxle other side is da axle
blox valve train and valves
greddy timing belt, hondata i/m gasket b and m fuel presure regulator
balance shaft removal kit already installed
manual timming belt ajuster
balanced f22 crank and rods, jdm h22 pistons
arp head studs honda bearings
new oem oil pump and water pump valve job was also done when motor was built
obd1 wireing harness
xtd 6 puck cluth and 12 lbs flywheel
m2b4 lsd h22 tranny no grinds
most gaskets where replaced in the motor
selling to rebuild a 2000 py itr
brand new crower stage 3 cam, skunk2 i/m and skunk2 cam gears not installed
make offer no lowballers plz
jaydec11
Jul 10, 2013 08:19 AM
erocksitr
Northern California (Sales)
Mar 13, 2008 09:04 PM
O RLY
Mar 9, 2006 07:17 PM
