Suspension & Brakes Theory, alignment, spring rates....
GC thread body removal off Koni shock help!
Old Mar 16, 2008 | 09:39 AM
redrelease's Avatar
Default GC thread body removal off Koni shock help!
Ive been search for a while now and have not found how to remove the read threaded cylinder from the Koni shock. I know it sits on the snap ring, but in theory shouldn't it just slide off with enough force??
I had an ek, now I have a dc2 and bought 2 new rear shocks, im switch the GC's onto the 2 new rears and can't get this threaded perch off to save my ***. Any insight would be helpful. Thanks.
Old Mar 16, 2008 | 09:27 PM
CEMAYHALL's Avatar
Default Re: GC thread body removal off Koni shock help! (redrelease)
I would try and hit the bottom of the sleeve with a hammer...
Old Mar 17, 2008 | 12:32 AM
redrelease's Avatar
Default Re: GC thread body removal off Koni shock help! (CEMAYHALL)
tried beat it with a rubber mallet, took a chunk out of the mallet. A hammer dents the **** out of it. These were order straight from gc preinstalled. I know someone has done this before, anything will help at this point.
Old Mar 17, 2008 | 01:41 PM
slammed_93_hatch's Avatar
I'd say that there is a bunch of gunk and grim in there making them hard to get off.
I'd try hitting it better with a mallet maybe even use a 2x4 so you can get a better hit.
Old Mar 18, 2008 | 09:32 PM
stumpyf4's Avatar
You probably have rust between the sleeve and shock body, soak the assembly in penetrating oil. Spray between the shock body and the sleeve. Re-paint the Konis black, the yellow paint seems to chip off really easily.
ketchup!
Suspension & Brakes
11
May 9, 2011 03:46 PM
lkailburn
Suspension & Brakes
36
Jun 24, 2008 07:50 AM
da9pwnsu
Jul 17, 2006 06:37 AM
Danza
Suspension & Brakes
Jun 10, 2005 06:17 PM
SmasonGSR
Mar 22, 2004 12:26 PM
