clutch problem, can't get into gear
Old Mar 16, 2008 | 07:21 AM
packman5280's Avatar
Default clutch problem, can't get into gear
ok, so i just installed an exedy stage 1 racing clutch in my 00 si. the problem is that now it won't release all the way. i push the peddle to the floor and it won't go into gear. i can sometimes get it to go into 2nd, but the trans clunks when i do that and the car starts to move forward. so it seems to me that the clutch is dragging. i thought maybe the slave was bad so i replaced that, and it's no better, and worse if anything. at one point while changing the slave, the reservoir drained all the way, so is it possible that the master cyl has a bubble in it now? the fluid was really black, it probably isn't supposed to be right? what could cause that? is it possible that the extra force required for the stage 1 clutch is causing a problem? anyone had that sort of problem before?
thanks in advance for any help.
Old Mar 16, 2008 | 07:24 AM
JDM_SOHC's Avatar
Default Re: clutch problem, can't get into gear (packman5280)
sounds like a shot master cylinder... have u tried to bleed it like 100x yet..?? took me forever to get feeling in my clutch after i installed my ACT...
Old Mar 16, 2008 | 07:25 AM
no, but i've heard it may need that. like run a pint through it or so. probably try that here in a few minutes.
Old Mar 16, 2008 | 07:36 AM
JDM_SOHC's Avatar
Default Re: (packman5280)
just do the one person bleeding trick... u kno how???
Old Mar 16, 2008 | 07:38 AM
i dunno, please share. i tried it solo first, just cracked the bleeder and let it drip slowly. then a friend came over and we did it a few times just like you would bleed brakes.
Old Mar 16, 2008 | 07:50 AM
JDM_SOHC's Avatar
well yeah if u have a friend that can help u thats tight too, makes it a lil easier.. but yeah theres a lil trick with only one person where u get like a bottle of brake fluid, a small fishtank hose or clear hose that will fit onto the bleeder on the slave cyl, an a container or something that u fill with brake fluid about 3/4... u put the hose on the slave cyl an the other end into that container full of fluid, than you crack open the bleeder an just pump the clutch until there is no air bubbles coming out into the container, but make sure to keep filling up ur resevoir.... theres a writeup with pics somewhere shouldnt be hard to find but thats how u do it, pretty easy...
Old Mar 16, 2008 | 10:47 AM
well, i bled it forever, like 40 times, and still no love. it will go into gear, but it really doesn't want to. so i got under the dash and looked at the master and it was kinda spooging a little, and there was a stain on the floor under it like it had been leaking a bit. so i am gonna replace that and see how it goes. kinda makes sense, so hopefully it does the trick.
Old Mar 16, 2008 | 11:08 AM
edmek4's Avatar
did you change the release bearing?
Old Mar 16, 2008 | 11:51 AM
yeah, new pilot, new throw out bearing, new cover and disk, new flywheel.
Old Mar 16, 2008 | 01:15 PM
new master cyl is installed and it shifts like butter, so smooth. so glad i didn't have to drop the trans. now i gotta fix the leaky vtec solenoid, oil pan gasket, and front crank seal, and i'll have a good car again. thanks for the help.
bilabong750
Jul 20, 2008 07:19 AM
civicandr6
Mar 16, 2007 07:18 PM
ludelvr
Aug 20, 2003 10:00 PM
ludelvr
Aug 13, 2003 10:54 AM
JunIntegra
Mar 24, 2003 12:47 PM
