oil leaking from my head??? can you guys take a look and diagonse my problem?
Old Mar 16, 2008 | 02:10 AM
DC4R27's Avatar
Default oil leaking from my head??? can you guys take a look and diagonse my problem?
my front left corner of my head is leaking oil slowly.. its always been sorta dank and grimy. but today, i went out for a drive and romped on it for a bit seeing redline, and when i got back , i saw that the previous grimy stuff was washed off by a clean layer of oil that was leaking. looks like the pics below.
Is this a headgasket issue?
i need some expertise on this. thanks.
Modified by DC4R27 at 3:44 AM 3/16/2008
Modified by DC4R27 at 3:49 AM 3/16/2008
Modified by DC4R27 at 3:54 AM 3/16/2008
Modified by DC4R27 at 6:15 PM 3/16/2008
Old Mar 16, 2008 | 02:21 AM
BlueIntegraBoy's Avatar
Default Re: oil leaking from my head??? can you guys take a look and diagonse my problem? (DC4R27)
Has to be the headgasket since it's the only thing between the head and block.
EDIT: Now that there are pics, the issue isn't with the hg.
Modified by BlueIntegraBoy at 12:44 PM 3/16/2008
Old Mar 16, 2008 | 03:28 AM
DVSBIZZYB's Avatar
Check your compression. Check the cam seal, from the first picture it looks like there is oil in that area also.
Old Mar 16, 2008 | 06:21 AM
IN VTEC's Avatar
I have a leak from the distributor o-ring that drops oil like that after a while.
Old Mar 16, 2008 | 06:26 AM
DB8-TUNER's Avatar
Check your cam plug/seal, distributor o-ring, and the vtec spool valve/gasket if its a gsr. 90%+ of the time, its the cam plug/seal.
Old Mar 16, 2008 | 07:07 AM
ONE*SICK*FERIO's Avatar
Default Re: oil leaking from my head??? can you guys take a look and diagonse my problem? (DB8-TUNER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB8-TUNER &raquo;</TD></TR><TR><TD CLASS="quote"> if its a gsr. 90%+ of the time, its the cam plug/seal.</TD></TR></TABLE>
cam seal or valve cover gasket , i dont think is the head gasket
the gsr head on the pic's, its on full gsr swap or ls-v swap???
what is that brailed hose for??
looks to me like obd1 block with obd2 gsr hed"..what year is it??
Old Mar 16, 2008 | 09:08 AM
XSIintegra's Avatar
Default Re: oil leaking from my head??? can you guys take a look and diagonse my problem? (ONE*SICK*FERIO)
Thats not the HeadGasktet.
Its one of your top end gaskets. Look at all the residue on the head itself.
What series engine is that?
Check Cam End Seal, Valve Cover Gasket and Distro O-Ring
Old Mar 16, 2008 | 10:25 AM
littlej72's Avatar
From an acura tech, ill third the no headgasket, get an updated cam plug and put it in there while your at it replace the distributor o ring and make sure that your valve cover gasket is sealed. replace everything and clean it off really well with brake clean or something and recheck it. Any acura dealer stocks those parts and there cheap.
Old Mar 16, 2008 | 02:27 PM
Mohsin's Avatar
i cant believe some of the inaccurate info being given here, that is 100% not the headgasket. It is 95% the Cam PLUG and possible the vtec solenoid gasket. I replaced both and had exactly the same leak prior. Leak dissapeared.
Old Mar 16, 2008 | 04:30 PM
littlej72's Avatar
Default Re: (Mohsin)
Yeah the last few posts, mine included addressed this' He's on the right track.
Old Mar 16, 2008 | 05:40 PM
typeR#0427's Avatar
Default Re: (littlej72)
dont forget to check the hex bolts, they are the big ones on each side of the head, you cant miss them.
might not be it, but good to check if your already in there.
Old Mar 16, 2008 | 06:01 PM
[ iLL ] iNt3GrA's Avatar
Default Re: (typeR#0427)
dont worry easy fix, just follow the advice of changing the cam seal. They have billet ones
Old Mar 17, 2008 | 02:05 PM
DC4R27's Avatar
Default Re: ([ iLL ] iNt3GrA)
its a b18c1. its been leaking like that for a long time now, and so much dust and grit has accumulated that its covered the block stamp also, the underside of my block and tranny are all covered in that same grit.
Old Mar 17, 2008 | 02:07 PM
DC4R27's Avatar
Default Re: (DC4R27)
yeah, and there is a bit of oil leaking from somewhere on top of the big leak. I dont get how where the oil is at the head/block is a result of a cam plug/seal leak. it look like the source of the leak is where you see it.
Old Mar 17, 2008 | 02:10 PM
acright20's Avatar
yahh i highly dought its the head gasket
Old Mar 17, 2008 | 02:28 PM
GiT LaO'd's Avatar
I have the same leak in the same spot...Not to thread jack but mine was coolant @ first but then the oil started coming out...Its mostly oil now...
I was told headgasket because I have a lil white smoke from the head when I open up the oil cap...
So I'm now torn apart whethter to change headgasket after reading this thread...I have replaced the valve cover seal, the distributor....
Old Mar 17, 2008 | 02:37 PM
hatchling37's Avatar
Default Re: (GiT LaO'd)
Check your exhaust manifold gasket, too. Had a leak that looked identical to what you have going on there (in the exact same spot) and the previous owner, in their infinite wisdom stripped out the head stud right there on the end. Replaced the gasket and repaired the stud and booyah, no more leaky. Now, I just have to do my damn oil pan gasket
Old Mar 17, 2008 | 11:09 PM
DC4R27's Avatar
Default Re: (hatchling37)
i was drunk
Modified by DC4R27 at 2:29 PM 3/18/2008
Old Mar 17, 2008 | 11:42 PM
DC4R27's Avatar
i was drunk
Old Mar 18, 2008 | 12:43 AM
vshavoc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Check your exhaust manifold gasket, too. Had a leak that looked identical to what you have going on there (in the exact same spot) and the previous owner, in their infinite wisdom stripped out the head stud right there on the end. Replaced the gasket and repaired the stud and booyah, no more leaky. Now, I just have to do my damn oil pan gasket </TD></TR></TABLE>
If you think oil leaks out of the exhaust manifold gasket you shouldnt be working on cars dude!!!!!!!
Old Mar 18, 2008 | 01:35 PM
DC4R27's Avatar
Default Re: (vshavoc)
yeah, today i took a better look at the cam seal, and it does look like its a little wet on the bottom. man, i didnt know so much oil could leak from there. my whole tranny and block are black because of the oil and dirt. could having a bad cam seal cause power loss?
Old Mar 18, 2008 | 02:59 PM
DC4R27's Avatar
and if oil is leaking from the distributor, im assuming id be seeing oil around the distributor cap?
Old Mar 18, 2008 | 05:25 PM
lsvtek's Avatar
hmmm... Id like to know as well where his leak is. I have the exact same problem after i did the LS Vtec swap. I think ill change the valve cover gasket and use hondabond this time.
Old Mar 18, 2008 | 09:15 PM
DC4R27's Avatar
Default Re: oil leaking from my head??? can you guys take a look and diagonse my problem? (lsvtek)
i just checked the underside of my distributor. theres oil leaking from there. so its the distributor o ring then and possibly the cam seal?
Old Mar 19, 2008 | 05:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vshavoc &raquo;</TD></TR><TR><TD CLASS="quote">
If you think oil leaks out of the exhaust manifold gasket you shouldnt be working on cars dude!!!!!!!</TD></TR></TABLE>Didn't say it was oil, horse's ***. Said it looked identical to the mess he has going on there.
It's not the cam seal, or the dizzy gasket, unless you can see the sludge on the head, too. Heard of gravity? Pulls stuff down, even if you're flying low.
