Problem with Power Lock
Car is 95 Accord Sedan EX
The problem is the lock on the driver side rear door, it sometimes lock and sometimes it does not, I do not have problem with the window going up or down its just the door lock.
Now do I need a new regulator?
And the passenger side front the window is hard to go up when its down, do I need a regulator on this one?
Thanks
Thanks
It sounds like you need a door lock actuator. But check the connections just for grins.
Try cleaning and lubricating the window run channel; silicone spray is a good lube.
swminnesotan
Oct 7, 2004 07:05 AM
rsidhu
Sep 2, 2004 06:08 PM
jArceo
Jun 22, 2004 07:59 PM
