axles for b16 into eg swap
Old Mar 15, 2008 | 08:29 PM
NeonPinHead's Avatar
Default axles for b16 into eg swap
will the 99 civic Si drive shafts work?
Old Mar 15, 2008 | 08:32 PM
crazyguy's Avatar
Default Re: axles for b16 into eg swap (NeonPinHead)
yes. if u are using 94 and up integra intermediate shaft.
Old Mar 16, 2008 | 02:58 PM
well i'm looking to buy new drive shafts for the swap i don't want to frankinstein it. so which stock drive shafts would work for the swap? the del sol vtec ones maybe?
Old Mar 16, 2008 | 03:02 PM
egsleepercivic's Avatar
the following axles will work,
any 94-01 teg exclude jdm type r
99-00 civic si
94- 97 del sol dohc vtec axles
all of these axles are the same, except for abs
if your car is non abs you can use abs or non abs axles, if your car is abs then you must use abs axles
Old Mar 19, 2008 | 04:18 AM
Perfect thanks
95 civic b16
May 5, 2009 11:06 AM
17
Oct 1, 2006 06:40 AM
OVA
Mar 19, 2005 09:00 AM
j0nptw
Feb 18, 2005 10:12 AM
94si94cx
Oct 23, 2002 05:16 AM
