SIR EF 9 cluster help
I installed a SIR EF 9 cluster via http://crx.hacki.st/gauge-cluster.html and it all works but my spedo goes to 60 KM as soon as the key is turned in the on position and while car is running . I have it wired up in my 1991 HF CRX. I kept the HF harness and added the Vtec sub harness for the engin. My cluster came out of the same EF9 that my B16a and LSD Y1 came out of with the VSS/ESS all from the same car. My thoughts were it did this since the ESS/VSS was not put it in yet but now it is installed and the cluster still does the 60 km thing. Any thoughts. I rechecked all the connections as they are soldered and taped. I narrowed it down to the 8 pin cluster connection...I cut the Black/Yellow +12v input and the cluster goes to zero but now what. Any suggestions other than the cluster may be bad ?
