h22 high rpm smoke
Well as i aproached my car to go home....i cranked and it was misfiring... ....checked all the plug and saw that cyl #3 was full with gas...well i was forced to drive about 3 miles sounding like a subaru...with the injector stuck open spraying...shitload of white smoke and raw fuel coming out of the exhaust...i stopped and dissconnected the injector....when i got home i immediately looked for the problem...saw that the positive wire for the injector was pinched on the chassis....fixed it up right quick and tada problem solved...NOW for the problem im worried about....ALOT of white smoke is coming out of the exhaust at high rpms...then i let it sit idle and the smoking goes away for a bit till higher rpm's once again....i checked the collant levels and they are fine...
how long has it been smoking since you fixed the injector? it may take awhile to clean all that **** out, if your coolant is fine and your oil isnt milky i wouldnt worry to much about it now but if it doesnt go away there may be another issue
bpfergu
Mar 5, 2012 05:27 PM
viper_2_4
Aug 15, 2006 09:51 PM
lowRIDAH
20
Jun 30, 2006 09:01 AM
