Do I need an alignment after....
replacing the front rotors on my 96 accord lx? anyone know off top of their head how long it took to replace the rotors using the pulling off the knuckle method? thanks.
If you pull the knuckle with out unscrewing the outer tie rod ball joint, I wouldn't worry about an alignment.
You can usually loosen that nut on the outer joint and smack it with a big hammer where the stud goes thru the knuckle part and it will come loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fern413 »</TD></TR><TR><TD CLASS="quote">no</TD></TR></TABLE>
x2 drive it and enjoy quiet brakes
should i put anti-seized on the four bolts behind the knuckle? also what about the splines on the axle? i had a tough time pulling it out so i had to pry it out.
thanks for the reples.
i coated the crap out of my bolts holding the hub in, i had more than a hell of a time getting em out, stripped the head off of 2 or 3 of em. the axle is gunna suck most of the time, i wouldnt worry about that one
LOLO93PRELUDE
Jun 26, 2008 03:09 PM
