h22 high rpm smokes :(
Old Mar 15, 2008 | 01:55 PM
nightrider93ex's Avatar
Default h22 high rpm smokes :(
Well as i aproached my car to go home....i cranked and it was misfiring... ....checked all the plug and saw that cyl #3 was full with gas...well i was forced to drive about 3 miles sounding like a subaru...with the injector stuck open spraying...shitload of white smoke and raw fuel coming out of the exhaust...i stopped and dissconnected the injector....when i got home i immediately looked for the problem...saw that the positive wire for the injector was pinched on the chassis....fixed it up right quick and tada problem solved...NOW for the problem im worried about....ALOT of white smoke is coming out of the exhaust at high rpms...then i let it sit idle and the smoking goes away for a bit till higher rpm's once again....i checked the collant levels and they are fine...
Old Mar 16, 2008 | 09:57 AM
Default Re: h22 high rpm smokes :( (nightrider93ex)
ttt
Old Mar 16, 2008 | 08:51 PM
vlang29's Avatar
do a compression test
nightrider93ex
Mar 16, 2008 09:57 AM
b16nonoy
Feb 22, 2007 09:57 AM
lowRIDAH
20
Jun 30, 2006 09:01 AM
808eg6
Feb 24, 2002 06:25 PM
