Allmotor H22 skunk2 Stage 2 cam's. Vavle to piston clearance problem
Old Mar 15, 2008 | 12:40 PM
mafia's Avatar
Default Allmotor H22 skunk2 Stage 2 cam's. Vavle to piston clearance problem
Hey guy's Im going to get my head rebuild next weekend. And I have bin reading around the fourms and read that people had probelm with getting there exhaust valves bent with stock bottem end with skunk2 stage 2 cams.(https://honda-tech.com/zerothread?id=2246476) Were im going with this, is that I allreaddy bought all Skunk2 vavletrain with skunk2 cams and cam gears. And yes it will be on stock bottem end. So if this probelm is true, what options do i have? Can I (or my tunner) adjust the cam's timimg to avoid this problem? It will get tuned on hondata S300 (if that makes a difrance) Thanx on any input (I know I should of done resurch before buying them, but thats too late now and I dont feel like buying different ones)
Old Mar 15, 2008 | 01:48 PM
mgags7's Avatar
dude you need some serious spelling lessons
If you can, get different cams, if not, you'll have to set the gears, then clay it and make sure everything's fine.
Old Mar 15, 2008 | 02:35 PM
mafia's Avatar
Default Re: (mgags7)
Sorry about my spelling, I am russian. But thanks for the input. ill look into that.
Old Mar 15, 2008 | 03:15 PM
2Point3's Avatar
Default Re: Allmotor H22 skunk2 Stage 2 cam's. Vavle to piston clearance problem (mafia)
will the skunk2 pro 2's clear the jdm type s pistons???????????/
thanks
Old Mar 15, 2008 | 05:39 PM
98vtec's Avatar
moderator emeritus
Default Re: Allmotor H22 skunk2 Stage 2 cam's. Vavle to piston clearance problem (2Point3)
buy them and find out by claying.
Old Mar 16, 2008 | 12:52 AM
GoldLudeRay's Avatar
im running the stg 2 cams in a stock usdm piston motor i also have the head milled .030 as well i did clay the motor prior
Old Mar 16, 2008 | 02:16 PM
mafia's Avatar
Default Re: (GoldLudeRay)
Sorry, but what and how do i do "clay" My 1st time hearing this. thanks for all the info guys.
Old Mar 16, 2008 | 02:43 PM
mafia's Avatar
Default Re: (mafia)
OK, guys thanx for all the help I found out how to get this right. Just what kind or clay do I use and were can I get it? I found a walk threw on how to do clay (http://www.c-speedracing.com/h...y.php)
Scott53092
Oct 17, 2010 06:13 PM
panda_eh2
May 1, 2008 08:16 AM
Silvertc
17
Feb 22, 2008 01:07 PM
Forrest Gump 9
Mar 27, 2006 12:42 PM
crazzeboost
Oct 9, 2004 06:51 AM
