H22 into a 92 si
Old Mar 15, 2008 | 10:46 AM
13g-crx's Avatar
Default H22 into a 92 si
I don't mess with preludes much but a friend of mine has came to me for advice so here I am at your mercy . He has bought a 92 si that the crank pulley bolt sheared the end of the crank off. He's wanting to swap in a jdm h22. Is this just plug-and-play? Is the main difference between the two (h22-23) just in the head. I know we'll have to use the vtec ecu but not sure what all will have to be wired. Which tranny is best to used? Any advice is appreciated.
Old Mar 15, 2008 | 10:49 AM
Hawkze_2.3's Avatar
Default Re: H22 into a 92 si (13g-crx)
Have you checked the Prelude FAQs?: https://honda-tech.com/zerothread/2168311
Old Mar 15, 2008 | 11:10 AM
Acidcrakker's Avatar
Default Re: H22 into a 92 si (Hawkze_2.3)
Search for threads created by acidcrakker.
I have a parts list on going h23 to h22.
Old Mar 15, 2008 | 03:13 PM
13g-crx's Avatar
Yes I have read through the faq's. I didn't find much info for my particular situation. Why can't I swap out just the longblock keeping the original h23 intake manifold and accesories?
Old Mar 15, 2008 | 03:24 PM
Default Re: (13g-crx)
not to be a dick, but did you even bother searching for that thread I was telling you about? It should contain the info you want?
Old Mar 15, 2008 | 03:27 PM
13g-crx's Avatar
Yeah... all I really saw was different replacement parts like gaskets and stuff. I don't see why thats relevant to swaping the new engine in. I'm also not trying to be a dick and I appreciate the response.
Old Mar 15, 2008 | 03:42 PM
Well if you look closely at it. Its a parts list for going H22 from H23. You need to wire in the vtec wires. Other than that its basic swap.
The M2B4 tranny is ideal, but you will also need new axels for that tranny.
The H23 tranny will bolt up, but the m2b4 tranny is faster at accelerating
Old Mar 15, 2008 | 03:47 PM
13g-crx's Avatar
Thanks a million! Would things be simpler if he found a usdm h22?
Old Mar 15, 2008 | 03:57 PM
Yes and no. Its not that hard to take a JDM motor and make it USDM. You can use the fuel rail off the current motor, and bam its USDM compatably.
The h22a has a better rep than the H22a1(usdm)
Old Mar 15, 2008 | 04:04 PM
13g-crx's Avatar
Cool. Damn dude, you are the man in prelude world aren't you?!?!! Thanks!
Old Mar 15, 2008 | 08:01 PM
ZephanK's Avatar
I did the JDM switch into my 94si; it went in with little problems. That said, make sure you pay attention to the wiring (you'll need a new harness). I thought mine was all correct only to find out my cruise control didn't work anymore. That's my only advice; hope that helps.
Old Mar 15, 2008 | 08:09 PM
13g-crx's Avatar
Default Re: H22 into a 92 si (ZephanK)
Hmmm?? What harness will I need?
Old Mar 15, 2008 | 09:44 PM
vlang29's Avatar
you can use the h23 harness, the only thing you need to do is wire the vtec solenoid and vtec oil press switch. Some non-vtec preludes come pre-wired for vtec, the wires go into the engine bay, all you need to is extend the wires
Old Mar 15, 2008 | 09:46 PM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZephanK &raquo;</TD></TR><TR><TD CLASS="quote"> my cruise control didn't work anymore.</TD></TR></TABLE>
check to make sure all the vacuum lines are all still connected and didn't get bumped during the swap.. I didn't change anything with the cruise system, and it still works after the swap
Old Mar 15, 2008 | 09:49 PM
98vtec's Avatar
moderator emeritus
Default Re: H22 into a 92 si (vlang29)
we dont even have a 4th gen h22 swap thread.....maybe we should make one...
Old Mar 16, 2008 | 11:53 AM
Hawkze_2.3's Avatar
Default Re: H22 into a 92 si (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">we dont even have a 4th gen h22 swap thread.....maybe we should make one...</TD></TR></TABLE>
I thought we did....it's such a common swap and people make threads about it all the time.
Old Mar 16, 2008 | 12:33 PM
M2B4's Avatar
the 92 was not prewired for vtec so you will have to run the 2 wires. also if you get a jdm h22a. it would be easiest to simply use the distributor from the h23. plugs right and bolts right up. and with the fuel rail like said you can use the h23 fuel rail just put the h22 injectors in. everything else is pretty standard.
Old Mar 16, 2008 | 01:16 PM
vlang29's Avatar
this thread is very useful for the h23-h22 swap
http://www.automotiveforums.co...11027
Old Mar 16, 2008 | 01:57 PM
I started this one, its for the parts list for doing a h23-h22 swap.
Clicky
310sieg
Jun 30, 2007 09:28 PM
LOW-LIFE
Jun 30, 2007 05:00 AM
92hondalude
Aug 6, 2004 08:42 AM
sirrach
May 7, 2003 12:17 PM
Slow CX
Feb 15, 2003 08:11 AM
