RE: Check Engine Light on 93 Honda Civic
Old Mar 15, 2008 | 08:36 AM
Buddy10297's Avatar
Default RE: Check Engine Light on 93 Honda Civic
Hello Everyone,
I had a 1992 Honda Civic manual transmission that crashed but the engine was untouched. I was able to obtain a 1993 Honda Civic automatic shell that I used to transplant everything from my 1992 Honda Civic into. On testing the car at around 50-60mph the check engine light comes on. When I checked the code out it gives a code 43 & code 1. My 1992 Civic never gave me these codes. According to what I have been able to research these codes are for fuel and the oxygen sensor. Would anyone be able to help me trouble shoot this? Thanks, Victor
Old Mar 15, 2008 | 09:23 AM
Crx_Civic's Avatar
Default Re: Check Engine Light on 93 Honda Civic (Buddy10297)
what o2 sensor did u use...if u just used the one form the automatic it could of been bad to begin with...as far as fuel you need to be a little more specific....
Old Mar 15, 2008 | 09:24 AM
z6hatchboy's Avatar
What trim levels are you dealing with, some have diff. wire o2 sensors. If there the same wire o2's just replace the o2, i've heard of people having code 43's and a new o2 fixed it.
Old Mar 16, 2008 | 04:30 PM
Buddy10297's Avatar
Default Re: Check Engine Light on 93 Honda Civic (z6hatchboy)
I did a complete transfer over so there was nothing conflicting with the oxygen sensor for manual vs. automatic. I will put in a new oxygen sensor....hopefully that helps. Thanks.
Old Mar 23, 2008 | 06:36 AM
Buddy10297's Avatar
Hello,
I changed the oxygen sensor but the Check Engine Light still comes on when I'm doing 50-60mph. It still gives a code 43 & code 01. When I drive 30-40mph around town the light doesn't turn on. Any Ideas? Thanks.
Old Mar 23, 2008 | 07:21 AM
egsleepercivic's Avatar
what trim was the 92, what trim was the 93
Old Mar 23, 2008 | 07:45 AM
Buddy10297's Avatar
Default Re: (egsleepercivic)
The 92 Honda Civic was a 3 Dr hatchback DX manual transmission. The 93 Honda Civic is a 4 Dr DX automatic transmission. I hope this is what you mean cause I'm a little confused as to what the trim level is. Thanks.
Honda d16a6
Jul 16, 2012 07:56 AM
javiertololo
Honda Civic (2001 - 2005)
Jan 10, 2012 03:26 AM
vtecgod
Apr 2, 2009 06:44 PM
oodie
Nov 16, 2008 04:46 PM
2camsaam
Feb 17, 2003 05:58 PM
